- Joined
- Sep 28, 2002
- Threads
- 558
- Messages
- 8,124
- Location
- Kamloops, BC Canada
- Website
- www.shopraddcruisers.ca
I thought it fitting to start a new thread since we are starting to rap up this project.
1HZ H55 Split case SOA OME Hydro assist 37MTRs Opposite Lock fuel tank.
One question to all, the cross memeber is so far forward (factory position) that I cannot clear it with the front drive shaft under full droop. Even with a CV off a later cruiser, it would take a fair bit of grinding on the cross member to have it clear.
My next option is the drive shaft is to short anyways, what if I had a spacer machined to go between the drive shaft and flange. After measuring it looks like a 4 inch space would make the drive shaft clear and also solve the cross member issue.
Digi has dead batteries, some shots later tonight.
