Alright guys I'm going to start my build thread it's going to be a slow process but I intend on working on it whenever I have free time from work. (don't have much)
It's a 1971 FJ55 with a 1976 FJ40 2F. It arrived from Tucson on May 14, 08 sense then I have taken the Oil pan down and the oil pump off due to the pressure relief valve being jammed. Oil pump on the way. Also I have already replaced the break lines to the front end. (gone) The PO had discs but took them off and put them on his 74. Alright enough with the computer back to the garage.
on your
purchase!
That last one hit too close to home
Lookin forward to progress pics ;p
ing to do. Little bit of fabbin goin on too
The headliner is tucked under all the window weatherstripping, so you know what's next
I'm glad I didn't try & reinstall mine........
Since the hole is in the corner, I bet you can just pull it back far enough to where you may not need to mess w/ the window w/s. Stick a vacuum nose up there & suck out the rest of the fallen particles in the other area that needs work........
