Yaesu FT-8900 Overhead Console Installation - FZJ80 (1 Viewer)
Stuck between a rock and a hard place
Once I passed my Technician License test several weeks back, I went to the local HRO to pick up a radio to install into my 80.
I was definitely looking at doing the remote-style of installation, and settled on the Yaesu FT8900. The radio has a number of features which appealed to the OCD side of me, and not wanting to have to "upgrade" the radio in the near-future. The radio itself I planned on mounting in the PS rear panel "box" which originally housed the factory hitch and tow harness.
Once home, I started looking at where to install the remote head. My dash already had quite a lot of buttons and switches, plus the CB installed into the ash tray. Lo and behold, I find out that this radio would fit perfectly into the OH console that I had left over from my Subtank install. I sold the compass and fuel gauge assembly to another Mudder, but kept the actual console.
My first task then was to find a good mounting platform for the radio and mic. TAP Plastics came to mind, and I went there with the console in hand. I had them cut and bend a piece of black 3/16" plexiglas 1" x 3" x 9" at a 100 degree angle. This was the stock that I then used my dremel to cut out to become the surface where everything up front would mount.
The microphone mount is a Gamiviti 60 series mount with a green LED for backlighting.
picture.php
picture.php
picture.php
With the rear, I cut a hole into the bottom of the box so that the radio could have a much larger space to dissipate heat. This also allows the headunit to be removed from upfront and the radio to be operated from the rear when in basecamp. What I really like is that when the panel is closed everything is hidden and out of harms-way.
picture.php
The radio has a direct feed to the rear fuse panel, which also has a direct feed to the dual battery. It is always nice when an install shapes up as planned...now onto getting the inverter setup back there.
:cheers:
Steve
Sweet!
The compass is worthless anyway. I really like this.
:cheers:
That turned out really nice! I like overhead installations myself and have radios in that location on both of my trucks.
I've got my 7900 mounted up high like that and I really like it. I used a RAM mount that I screwed into the holes for the mirror. Easy to see the display and make changes without taking your eyes completely off the road. I ran a long phone wire back down to the center console for the mic though. I think that dangling mic cable would get frustrating over time.
Nice, very creative Steve!
A new part for CDAN to carry - overhead console shell only!
Nice install!!!!!!!
Thanks for the compliments. I just received my new visors from Japan4x4 last night, completing my install. They were uber-cheap compared to the US Domestic versions...I gave up having lighted mirrors, but also only paid $55 a piece. Right color, right size, right price. After driving the rig four days last week without the visors, I am soooo happy to have these installed.
I love being able to listen into various NETs when heading to and from work; sure beats the local broadcast radio.
:cheers:
Steve
cyclosteve-albums-yaesu-ft-8900-install-picture20838-both-visors-installed-down-position.jpg
Looks good! I did something similar using ram mounts.
I still need to figure out a better way to mount the mic.
Do you have a model number for that RAM mount?
RAM-B-202U-1525
RAM-B-238U
RAM-B-201U-A
You'll have to do some grinding and drilling of the second one to get it to mount in the mirror slot (it will be obvious) and source two longer screws.
Nicely Done.
Nicely done install.
I have my FT8100 mounted using the rear view mirror bolts and a piece of 1/8" steel in my 4Runner.
Sadly, I don't have a the separation kit for mine (Yaesu stopped making parts for this thing years ago) so the whole unit is up there.
I need to get a pic.
Not nearly as neat and orderly as yours.
Nice install but I would love some guages in there.... can you fit 52mm VDO gauges in it and how deep is it? What are the dimensions of the gap where the radio is fitted?
It may work as the opening is 52mm high by 190mm wide by 60mm deep. The console material is flexible, or you could cut as necessary. Three gauges should fit in the space.
:cheers:
Steve
Thnx for the heads up.....now for the piece without internals. Cruiserparts sells them new. I have the wavy cloth roof interior, thats not a problem right?
I'm planning on doing this mod as well so I've been looking for the overhead console for a couple weeks. I found three sources: Cruiserparts.net has one, Toyota partszone, and Ebay Australia. I ended up ordering a used one off ebay Australia because it was the cheapest. I'ts currently on a slow boat to the US. The supplier had several and lists them from time to time.
I hope you sourced the sun visors to match as well.... or have some plan on how to modify/shorten the stock ones...
cheers,
george.
