OK. Here we go. I'd rate myself at somewhere slightly above total novice mechanic. I've done things like headers on an LT1, waterpumps on an XJ, and a timing chain and guides on a 22RE. Most of those went well, albeit a lot slower than the average mechanic. So I've decided it's worth it for me to try to save $1500+ by attempting a head gasket repair myself.
I'll be posting pics of my progress and asking a lot of questions.
Background:
I bought the truck just about a year ago... I wish I'd known more things to look for, as I suspect this issue was there when I bought the truck... but I was more concerned with lockers and a cheap price. This past winter, I started seeing weird things and at one point my heat started blowing ice cold and I found this in the radiator:
I immediately suspected the head gasket, but talked myself out of it, thinking it was a red/green coolant mix gone bad. I flushed it a few times and things seemed OK for a few months. However, I would frequently notice the sweet smell of coolant in my exhaust... but I was still in denial.
Finally, symptoms returned, I checked the rear heater hoses and discovered that they were already bypassed and my fate was sealed.
So, the magic journey begins. Fortunately for me, I have another vehicle to drive, so I'm not down. However, my schedule is very busy. I watch my two small boys (1 and 3) all day, and I work afternoons, leaving for work as soon as my wife gets home. She works most Saturdays as well, so my free time is very limited. Progress WILL be slower than most.
Step 1:
Ordered about $450 worth of parts from Beno who was super helpful in steering me to a nice landing spot somewhere between the bare minimum that should be replaced and the super extensive covering all bases twice HG + all PM stuff. I couldn't afford to go all out and replace the radiator and every little bit... but I think I will be happy with what I am replacing.
Step 2:
Ordered IdahoDoug's Head Gasket DVD. Watched it twice. I'm sure I will watch it a dozen more times in sections as I go.
Step 3:
a $275 trip to Lowe's for oddball tools (30mm socket, a "wobbly", PB Blaster, scrapers, scouring pads, etc, etc, )
Step 4:
Clean up the garage and make a nice space for working. Stocked up on rags, towels, handcleaner, set up my shop lights and got cracking
Step 5:
Drained the radiator and watched all of that pretty, red, fresh $40/gallon Toyota coolant pour out, never to be used again..
*pic coming*
Step 6:
Getting the hood off by myself was interesting!
Step 7:
Air cleaner removed
Step 8:
Heat shields and plug wire cover removed... a few of the holes around the heat shield bolts were getting corroded and flimsy... might have to try to score a new set.
Step 9:
I also managed to get the distributor and wires out. Thanks to paying attention to Doug's DVD, I removed the distributor and wires as one unit and that is one less thing to have to mark and put back together.
*pic coming*
Now I'm at the alternator and bracket. No pics of that yet, but I will add them.
*pic coming*
I have soaked the exhaust manifold bolt with PB Blaster and will hit them again tonight when I get home. I'm skurred about 20 years and 200k miles of Midwest driving...
Background:
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
*pic coming*
Step 6:
Step 7:
Air cleaner removed
Step 8:
Step 9:
*pic coming*
*pic coming*
