This is long and pic heavy, so i apologize, but not really. There are so many FAQ's on here that i have used i thought I'd take my time and document this to help others.
Reason i did this was something is draining my battery, not sure if the stupid blinky light was enough, but now that its out, time will tell if i solved the problem.. (i kind of doubt it)
The system in question is :
Step 1. Disconnect battery . Unplug system brainbox. Remove the plastic kick panel, the dead pedal, and i took out the drivers seat to make things easier and to give me space to work. Pull up the carpet to reveal the alarm harness and where it flows into the factory harness.
Follow harness cutting the zipties that hold all the alarm wiring to the factory wiring.
Step 2. Pull out the wiring from the little hole behind the kick panel. You will find a 4pin, and an 8pin connector.
Unplug the 8 pin connectors. it will be obvious which go to the alarm and which sides are the factoy and will stay. the wires are not that long, don't pull to hard.
Put the 2 ends together that are the factory side.
Next, the 4pin connector. Do the same. unplug the alarm side, and plug back together the factory side.
Step 2. Locate the 11pin connector a little further back twards the firewall in that same kickpanel.
Again, unplug the alarm side, and plug back together the factory side.
to be continued....
to be continued....
