ICON VEHICLE DYNAMICS Piggy-Back Prototype Shocks for the 80 Series
OC, CA, USA, EARTH SECTOR-28
www.tdubclub.com
ICON VEHICLE DYNAMICS is using my 80-Series for test fitment and specifications for their HD 2.5 V.S. Series Piggy-Back Shocks and the recently released V.S. Series 2.0 Aluminum Shock line. Both series of shocks will be available for the 80-Series in the near future, but dates are not set exactly and I will notify everyone through here once they are ready.
Pictured here is HD 2.5 V.S. Series Piggy-Back Shock
My truck going under the knife as they say...
I've known Dylan Evans, head engineer of ICON Vehicle Dynamics since his days at Sway-A-way with his extensive knowledge of both rock crawling and desert off road racing. I was able to give him a different discipline as he built a custom suspension system for my 1998 Ford Escort ZX2 Rally Car.
It was an awesome setup with 10" of travel and we used every ounce of it as we where not affraid of jumping our car!
OK, back to the 80-Series:
Look at the bling-appeal ICON has in contrast to the 200,000 miles of crusties.
ICON tested the stock spring rates - Front: 120lbs and the Rear: 160lbs
The springs will be adressed at a later date. It's a process, one thing at a time...
So, a little quick RTI - Ramp Travel Index Testing, the Fork Lift Way...
Rear tire was 27" off the ground.
I was impressed with how well my truck articulates in relitivly stock form, with just the the ICON HD Shocks! I think Dylan was impressed too as he said these numbers where as good if not better than a JK. Either way, I'm stoked!
We tested it with the steering at full lock to check for binding or scrubbing issues.
Then they lifted the front:
Front tires was 26" off the ground.
So, the TRI Score *684 to **691
RAMP TRAVEL INDEX - what it is all about?
Ramp travel index - Wikipedia, the free encyclopedia
HOW YOU MEASURE IT:
The distance traveled up the ramp is then measured and is divided by the vehicle's wheelbase and finally multiplied by 1000 to give a final RTI score. Most stock SUVs have RTI values from 400 to 550, vehicles modified for off-road competition have the ability to exceed 1000.
Ramp Dist Travel ÷ Wheelbase X 1000 = RTI Score
The 80-Series wheelbase is 2,850 mm (112.2 in)
Ramps Distrance [averaged between front 26" and rear 27'] so 26.5" average.
Ramp Dist Travel [26.5] ÷ Wheelbase [112.2] X 1000 = RTI Score 236.18
OK, this is not correct as most stock SUVs have RTI values from 400 to 550.
So a litle more digging and I found the mathmatical way to measure it as we tested it
RTI - THE FORK LIFT WAY:
Found this link: RTI Ramp - Ramp Travel Index Score - What is it, what does it tell you?
If using a fork lift you would measure the distance between the tire and the floor. With this measurement you calculate the score like this: Since a 20 degree ramp rises at .345 inches per inch of travel, divide the height of the lifted tire by .345 (for 20 degrees). Then divide that number by your vehicles wheelbase. Multiply that number by 1000. The result is your RTI score on a 20 degree ramp. While the ramp is a true measurement of your RTI this calculated method is pretty close. The calculator below does the math for you and allows for different ramp angles.
26.5 ÷ .345 = 76.811594202898551 ÷ 112.2 =
76.811594202898551 ÷ 112.2 = 0.684595313751324
0.684595313751324 X 1000 = *684.595313751323982
The result is my RTI score on a 20 degree ramp. While the ramp is a true measurement of the RTI this calculated method is pretty close. The calculator below does the math for you and allows for different ramp angles.
RTI Calculator [bottom of page] RTI Ramp - Ramp Travel Index Score - What is it, what does it tell you?
Your RTI score is **691Degrees Tested: @ 20° ramp.
The 80-Series would have traveled: 77.48081660432182 inches up a 20° degree ramp.
More to come!
Dylan Evans of ICON Vehicle Dynamics checking out the suspension on the Axial SCX10.
Testing is comprise of my daily commute driving on the 405FWY, off-road adventures, specific off road testing with the ICON team and specific cycle & fitment-testing on the rig as well as the dyno - shock dyno that is... Testing at current has just been fitment with light ride evaluation base on vehicle weight with bump and rebound consideration.
With the overly worn out stock springs, this has given the shocks a thorough workout, yet the ride has been dramatically improved plus I got about an inch bump in ground clearance! Yes, the stock shocks where TOAST! When I go around turns my mirrors don't drag the ground now and when I cross one speed bump it doesn't bounce like I'm in the whoops of Johnson Valley. NICE! It rides like a real truck should!
Plus, I have a wife and kids so it has to pass that "plush ride test" too! If its too harsh of a ride I will get an ear full!
Future testing will consist of adding different spring weights and heights and more shock tuning with each spring. It's a combination of spring and shock and they must work together, not overpowering one another. The stock Toyota Land Cruiser spring rates are very soft for the US market as Toyota Corp knew most of these rigs would never see a real dirt road.
Tell me you have RTI numbers before the mod.
Do you know the specs for the shocks? I'm most interested in compressed and extended length, and amount of travel it has.
I'm assuming it's a 10" travel shock?
And, this post has been on Expo forum for 5 days with no interest. Basically your pimping a shock with RTI numbers and not addressing a shock for what 80 owners want. 80 owners are not your standard crowd with Metal Militia stickers and 20" Rockstars and 40" tires on our junk wanting to have the coolest looking shock at the local Starbucks.
Give us real results from rolling on the 405 to The desert like you said. If you guys plan on just selling a shock valved to your rig than thats fine. For guys with high miles and no lift, who will get almost out this shock? If i had a cruiser with 200,000+ miles on stock spring and shocks any new shock from Checkers,Napa and VatoZone would feel awesome.
What i'm asking is to have a someone spend the time to have their shocks setup on different weight rigs. 80 owners have 3 types of setups light, medium and heavy.
Can YOU tell me who sells shocks that meet this criteria? I'm not asking for a fully adjustable shock which is basically impossible. Will ICON step up and do their research and produce a shock with 3+ different valving options?
Heres some links to check out...
https://forum.ih8mud.com/80-series-tech/245970-fox-shox-2-0s.html
https://forum.ih8mud.com/80-series-tech/303737-pro-comp-es9000-shock-information-specs.html
https://forum.ih8mud.com/80-series-tech/433712-doetsch-pre-runner-8000-shocks.html
Other Icon piggy-backs are $439 ea.
So these are replacements for stock cruisers??
Might want to lift it a bit and put on some beefier tires to do some real world testing.
At $439 a shock i'm out no matter what but i'll be watching to see how they do.
But with fox making their shocks for the 80 and most likely being half the price these would have to be worth their weight in gold to sway some I think.
He only just got them on i'm sure there will be more posts with conclusions.
subscribed! do we get NO FEAR stickers for subscribing to this thread?
:popcorn:
Classic! What is the upper mounting connection on the front shocks? I was quite impressed with the ride of ICON shocks on my buddies long travel FJ. From my experience, they are the real deal.
I know, I went on a rant after seeing a bunch of RTI numbers and from what I can see, real world testing on a stock rig with no added weight and high mileage suspension.
I like the testing SocalFj is doing on the Fox shocks. A little more real world on a heavy rig with normal suspension work average guys have.
I agree, I think the average 80 owner with a stock to semi stock rig isn't going to shell out the kind of money Icon normally charges. Now someone that has a built rig would be more likely to do that since they have already shelled out a ton of money to build up their rig.
But I still applaud Icon for making 80 specific shocks and i'm sure longer ones and some testing on built up rigs would also go a long way.
While I am kind of impressed that a company would bother making a high end shock for a vehicle thats been out of production for 14 yrs, it still doesnt change the fact that price wise Icon has always wanted the most $ for their products.
When building my ifs 00' tacoma I was going to go with coil overs for the front but what made the decision easy is that for the price of the front co's alone I was able to get a whole old man emu lift...... If you look at the 80 series aftermarket you could buy 1.75 icon shocks for the price of a complete ome kit (I paid 799). While I know the ome stuff isnt cutting edge, I just cant justify spending double the cash. I can see the majority of the 80 LC crowd thinking along the same lines, especially since Ive only seen a handfull of rigs with fancy shocks on mud.
Sure, there will be folks that will buy and love them, but I wont.
Add to that the fact that ANY aluminum shock/co would die in my salty winter conditions that makes the decision even easier. Icon does offer a treated shaft on its co's that is more resistant to corrosion but that comes at an added cost and doesnt really do much to protect all of the other shock components.
Now, I know someone will chime in with the whole "you have no clue about quality suspension" line and thats fair since Im not a rally/desert racing type.
D
D
you have no clue about quality suspension" line and thats fair since Im not a rally/desert racing type:flipoff2::flipoff2:
Really there is a huge difference between that and OME but like I alluded to in my earlier post that Fox that is also made and manufactured by peopel who do that kind of racing for a living are normally much less and already are doing testing for their 80 shocks and stabilizer on Dave Drucks rig. So I think ICON will have to dramatically come down in price for shocks designed for an older vehicle.
Don't forget about the available Radflo shocks too. They even make them for lifted LCs! They also have the correct stud mounting on top (not an eye) so you don't lose an inch or two of travel.
I will stick to my $50 BDS Hydros
They rock
And cheap to replace
That much for a shock is stupid
Most people will not notice that much of a difference in performance let alone $350 difference
Plus any body who will buy a shock like that would not be putting them on a stock cruiser
You guys need to get more realistic with your testing and use a rig that will actually get used hard off road
I hope the OP realizes that this is constructive critizism here. I just honestly don't believe that someone that just bought an old stock cruiser for 3k is going to dump another 2k in it for shocks..... something like the shortbus or another hard rode cruiser needs to be used for testing before anyone that would dump that kind of money into shocks would do it. Icons work for FJ cruisers and tacomas because they were designed for those vehicles when they were new and people had already dumped 30k into buying the rig so another 2k isn't that much more.
But I will say again I applaud them for making the effort where others have skipped our maket segment.
