Third row cup holder
Sandy Eggo
www.markkuz.com
Thanks to Vango who did this same mod back in 09' I finally got around to it and have detailed photos and directions.
1.) Score a center consold cup holder from a rig being parted out.
2.) Create a template from the passenger side of your center console.
3.) Transfer your template to your desired location. Be sure to make sure the back of the panel is clear of items in that location.
4.) If you plan to put it in the same location as me so the seat when folded up will clear the cup holder you will have to trim the bracket.
5.) You will have to trim the bottom screw tab so that it will fit right above the bump out on the panel.
6.) Although the panel was clear of those plastic snaps it doesn't clear the sheet metal that the plastic snaps pop into. So you will have to break out the dremel or cut off wheel so the bracket clears. Note my first cut was not enough so I had to cut a little more as you see in photo.
7.) Whala you have a third row cup holder!
8.) Final step, crack open a :beer: and put it in your new cup holder in between sips. :cheers:
Thats a lot of work for a cup holder. :D Hahahaha! Good work and write up!
What was more work and really sucked was when I went camping and I flip over my sleeper platform and :doh:
My new lot of work cup holder just screwed me! :o
But a little Jigsaw action when I got home fixed the problem.
i used the sienna cup holders that fold up flat in mine. then you just push the open button and you have a cup holder.
