Retrofitting an E-locker?
winchstoyotaparts.yolasite.com
Well, after 2 years of research and procrastination, I took the first step towards my SAS project. I purchased a '95 Landcruiser FJ80 front axle assembly. I got the coils, radius arms, Panhard rod, steering links, a set of new Rancho's, everything. Unfortunately, I couldn't find one with a locker, so I have to retrofit one in.
There is only one toyota E-locker, right? I could retrofit any E-locker from any Toyota into this diff (8"), right? Thanks.
LC 80's use a HP (High Pinion) in the front axle, so idealy you want a LC 80 front E-locker. But you might be able to use a regualr TRD E-locker out of a taco or 3rd gen 4runner, Im not sure on this?
There's a write-up on Sleeoffroad that might be able to answer your questions. there are also a ton of very knowledgeable folks in here with brains to pick as well.
You will need an 80 series font diff. A new diff lists for $1,151.81 and the housing will need to be modified. 4.10 is the only OEM ratio.
Considering the total cost to install an e-locker, even if one gets a buddy deal for one, you might think about just going ARB. The air locker will of course use all the parts you already have and only require setting up the ring and pinion. (New seals are nice anyway!)
In hard use on the trail the ARB excels over the e-locker for repeated use. I am referring to engaging and disengaging 4-5 times on some hard obstacles as you position then climb and reposition. If the intended use is more casual by all means the OE locker is a great tool but still carries the same price of admission.
Mark
Thanks for the reply. I just want to make sure we are on the same page. I purchased the complete front axle assembly with the diff from an 80 series, so I already have the diff. Or, are you saying that my diff will not work with the E-locker and I need to buy an E-lockered diff???
What they are saying is there is two different axle housing, they are different. The e-locker one is different from the non e-locker. As for the differential housing, they also are different. The e-locker is set up for the motor and locker assembly. So it looks like you have a non e-locker differential housing and axle housing/ The easyest way to go is to put a ARB into it and call it good. Or start again, buy a e-locker Axle with a e-locker differential. later robbie
So, if I buy an E-lockered diff and retrofit it by modifying the housing as they describe at sleeoffroad, I am wondering if I can take any E-lockered diff, like out of a 4Runner or Tacoma TRD, or if it has to be the front Landcruiser diff and locker? Thanks.
ARB is the way grasshopper. I thought about putting new axles with Yota e-lockers under my 92, and for the cost and the trouble, the ARB's proved to be much cheaper and just as effective.
Bear80 said:
does the issue of the reverse rotation matter??
Reverse rotation is a common misnomer for high pinion/reverse spiral/reverse cut diffs. There is no such thing as a reverse rotation diff. The diff is not spinning backwards, it is spinning forwards and the gears are reverse CUT to allow the pinion to be positioned on the high side of the ring gear as opposed to the low side.
Therefore, housing issues/mods aside, you could run a low pinion/standard rotation Taco e-locker in a front housing, and many do in the mini-truck housings.
Ary
Ary
Ahh, never really looked into that, good to know.
Ary
Okay, this is good news. So retrofitting a V6 8" diff and e-locker from a 4Runner or Taco TRD into the LC assembly, should be no different than retrofitting it into an old pre '85 Toy axle. Only disadvantage is that the driveshaft will be at more of an angle due to the low pinion, right?
I'm assuming you do not agree with:
CruisenGA said:
has to be the front landcruiser unit.
Honestly, I have no idea. My reply was just trying to clarify the reverse rotation issues. I would go with what everyone else is saying and just get an ARB for the current 3rd member you have, which is stronger than a low pinion TRD E-locker anyway(both because of the reverse cut gears up front and because the ARB is argued to be beefier than the e-lockers).
Ary
What is this?
Initially when I picked up the axle, I thought the hoses coming from the top and back of the driverside axle housing was for the vacuum sytem for the Automatic Disconnecting Diff, like in my Taco. Now I learned that the '95 Cruisers were Fulltime fourwheel drive. So, what are these hoses for and what do I do with them after I install it on the Taco? One hose is connected to a black box. There is also a connection between one of these lines and the brakes, and there seem to be oil or fluid coming from one line. (See pic below)
The one on the left is an axle breather. On the right is the LH brake hose/line.
As far as the diff goes you will need an 80 series top pinion diff to go in the housing, either locked or unlocked.
Okay, thanks. So, I should obviously put manual hubs on this. What do you recommend? Warn? Aisin?
I've put both an 8" TRD e-locker and an FJ-80 high pinion e-locker into the same toy mini 8" axle housing. The mating surfaces are the same.
In fact, I used the actuator from a TRD locker on an FJ-80 high pinion e-locker. The only difference, as far as I could tell, was the shape of the wiring connector. This is a plus as there are many many more actuators available used, rather than paying ~$400 from the dealer for a new one.
www.car-part.com or the classifieds on here....
If I were retrofitting, I'd just do it with complete axles. You can find them for not much more $$ than the diffs alone usually cost ya. IIRC its pretty much impossible to use the non-elock front axle housing for an elock diff retrofit on an 80 series anyway.
Having retrofitted two toyota 8" axle housings for Toy e-lockers , I'd much rather do an axle swap, for multiple reasons:
1. Modifying the axle housing to fit the e-locker 3rd member requires lots of work (from my point of view). You have to remove the axle to do the work anyway, just as you would have to do an axle swap.
2. The price wasn't that much greater to just get an axle at a yard vs. an e-locker when I was looking.
3. Availability of front axle high pinion FJ-80 e-lockers on car-part.com is going down, and the price is going up. You could probably get a new one from cruiserdan for just a little more $$.
4. The yards I called often don't know exactly what they have, but will gladly sell a mis-identified part. This is an annoying experience.
If you do decide to order an axle used, make sure it comes with the 3rd member, and other necessary parts. Often these and other parts are listed separately.
Why does he need a high pinion diff? Is it because of the antiroll bar and/or steering linkage?
Dont forget about the ECU, harness, and switch you'll need as well. The ARB really starts to sound like the smooth way to go.
