a v6 8" diff would bolt in, but it would not be as strong, you would have more driveshaft angle, and if you are running steering like an 80 your tie rod will be in the way. If you use a taco trd unit you would have the same welding/grinding/tapping etc. ARB would be time and money ahead.
Okay, this is good news. So retrofitting a V6 8" diff and e-locker from a 4Runner or Taco TRD into the LC assembly, should be no different than retrofitting it into an old pre '85 Toy axle. Only disadvantage is that the driveshaft will be at more of an angle due to the low pinion, right?
I'm assuming you do not agree with:
Thanks
