While working on my stereo install, I noted that there are 2 unused plugs under there that I would like to identify.
I believe one is the plug for the CDL switch connection. Wrapped in foam at the back of this wire set.
The other is behind the stereo, yellow 4 pin connector, nothing nearby to connect to. 1st pic of connector as it sits, 2nd pic is me turning it so you can see the pins.
Thanks for any and all insight.
Randy
Randy
