Hi all started to get something on the move with the new toy: https://forum.ih8mud.com/80-series-tech/365673-my-lc-80-thread.html
But need some help from the leccy guru's.
I have had a look at some of the search results but they did not help except confirm I had chosen the correct lock/unlock wiring colours.
So, I'm midway in fitting a Clifford and EVERTHING works perfect until I shut the drivers door!! Once the drivers door is shut the alarm will set ok and lock the doors. Press the remote to switch off and unlock and the alarm switched off but the doors will not unlock!
Now the tests I have done:
All doors closed except the drivers door,
Remove alarm connections to central locking, put a direct earth to the blue/yellow, doors lock perfect.
Remove earth and transfer to blue/orange, doors unlock perfect.
Repeat with thedrivers door closed and the unlock command refuses.
Connect alarm lock/unlock wires and again all is perfect, you can do this all day locking and unlocking the doors via the alarm key fob. This is untill you press in the drivers door button i.e. interior light off and the doors refuse to unlock from the alarm or even from direct earthing.
Once you have attempted to open the doors via the alarm or direct earth with the drivers door closed then the system needs 'resetting' from the drivers door via the key, unless you reset via the door key even the door lock control button on the drivers door will refuse to unlock the doors.
I have pulled all the door switches and all appears to be normal with a single wire for earth switching on each one. I pulled the two interior lights and the rearmost one had been modified but only by drawing off a live to somewhere in the drivers side rear door pillar (C), I disconnected this and it appears to do nothing?
I removed the door earth trigger for the alarm thinking this may be related but that did nothing except stop the alarm from sounding whebn the doors were opened which is what you would expect.
So we are left with the fact that closing the drivers door and if you like removing the earth to the interior light and of course the door open light on the dashboard prevents the alarm from unlocking the doors.
By closing the door I am removing an earth from somewhere in the door control system because the door control electronics fail to 'latch' in preparation for the unlock commmand.
This only happens to the drivers door and all other doors work fine.
I consider myself quite 'savvy' with electrics and often build 'one off' electronic gadgets and yet this does not make sense at all, what am I missing?
TIA
regards
Dave
TIA
regards
Dave
UNTILL the drivers door is closed and then it will lock but not unlock!
