Problem with tranny overheating¿
transworldexpedition.com
Hola,
here is again your favorite novice. thanks in advance for the assistance. i am now in south mexico, and the truck is getting really hot. the water temperature is ok, but the heat inside of the truck is unbelievable. the hotst part is the area in the center of the car, at the level of the left leg of front passenger. suspected the tranny, and changed the liquid yesterday. still overheating. the truck was always hot, but never like that. any suggestion¿
right now going slow until guatemala, where i will be able to find parts, and possibly bring transmission down.
muchos gracias
I can't offer much advice on the subject. But how is the truck driving? I mean are you noticing any strange behavior aside from the heat?
I read your blog and you mentioned a loud exhaust, is it possible one of your catalytic converters has a hole in it? Check that area of the exhaust closely and I'm sure you will find your problem.
Nicolas,
Your blog says you lost an O2 sensor and had it reinstalled. And that the exhaust is loud, as in you have a leak? The heat could be from the exhaust, which is on the passengers side.
Trans World Expedition
I doubt the heat is related to the tranny, since you are not experiencing physical shifting issues. When you say you changed the liquid in the tranny - did you drain 4 quarts and replace 4 quarts? There is more to the system than that, but overall you don't want to have the system 'flushed' nor should you be replacing fluids based on interior heat alone. If the tranny is shifting fine, I'd leave it alone. You definitely do not want to ask a shop to drop the tranny and open it up.
When you say "overheating" is this referring to heat felt by the passenger? You say the temp gauge is not running hot, and there is no physical overheating (as in boiling-over liquids) so we're back to excessive interior heat. The tranny, if it was cooking, would be hot on your right leg as well, so I think you need to investigate something else.
OK, all good points. All the sensors shows fluid temperatures are OK. The heat is just felt inside of the car. The center console gets really hot. The car feel OK to drive.
I originaly thought the heat could come from the exhaust leak, but that is really a lot of heat. It is still leaking a bit.
I also got some 401 and 420 codes recently.
Since few days, i drive with the hood slightly open, which did bring the temperature down. I think i can make it to Guatemala, and a toyota dealership.
The change in tranny fluid didn´t bring the temperature down.
Thanks for the help!
N
the temps in and around the catayltic converter stay around 1200 F durinig normal operation, and they can reach upwards of 2200 F if unburned fuel is entering the converter. So extreme heat could definately be derived from these parts which happen to be right were your experiancing the excessive heat. I would double check the exhaust. Take care and great blog!
is it possible you just lost a heat shield over the cats or exhaust pipe?
If so, try setting up a piece of sheet metal, even aluminum foil, between the floor and exhaust system
(unlikely: something going on with the rear heater?)
I know an excellent mechanic in the area that I could help you find via PM if it helps. But, I suspect one of several things are causing this. Many of the posts above already mentioned some:
1. Hole in exhaust causing extremely hot exhaust gas to heat that particular place on the front floorboards.
2. Clogged up catalytic converter causing higher operating temperatures all around the cat/s themselve/s
3. Exhaust system heat shields missing or exterior firewall heat fabric missing or jute pad missing in the interior carpet layer.
4. Center console heater getting hot coolant even when the temp switch is set to cold.
5. EGR system getting too hot.
Hope this helps. :cheers:
BTW, what is your blog? I think I'd be interested in it.
FWIW; this past summer I had to disconnect the heater cable from the heater valve because even set all the way to the left (cold), the heater valve was still about 1/2 open causing it to always be baking hot near the center console. Might be something to try, but what everyone else said is probably more important.
That would be something to check, but be aware that you can adjust it properly with another 30 seconds of work. There is a little metal clip that holds the cable sheath (outer sleeve) to the bracket. With the key on and the heater in the full cold position, pop one end of the clip loose and adjust the cable so it holds the valve in the cold/closed position. Snap the clip closed and you're done. Fully operational heat once again!
As for the OP's problem, start with a few things first. Check the transmission fluid level and coolant level and make sure they are at the proper levels. Check the exhaust and see if it has any noticeable holes(The 420 code is usually related to an exhaust leak between the two O2 sensors). I would not tear into the transmission as these things are known to be very reliable and I would hate to compromise that for no reason (at this point). Check and see that your heater valve is fully shut as Kernal suggested (you would notice warm air coming from the front vents too if the valve is not fully closed).
The passenger side floor and transmission tunnel is generally the hottest place in the 95-97 trucks. The exhaust runs under there, the cooling lines for the transmission run past there, the transfer case (arguably the hardest working mechanical component with the least amount of lube on these trucks) is biased to the passenger side, and the coolant lines for the rear heater are attached under the floor. All of this creates a high concentration of heat under the passenger side floorboard and transmission tunnel. So it is normal for that side of the truck to be hotter than the driver's side. It shouldn't be too hot to touch though. Having the hood slightly open (safely attached though!) would create more airflow over the engine and through the transmission tunnel, alleviating some of the heat so it is a temporary solution at best.
Once you have done a full checkup on all the suggestions given in this thread come back and let us know if you find anything. Without more info all we can do is guess.
:cheers:
96r50: Thanks for tip, just need a step stool to reach it properly.
Nick, it definitely sounds like a hole in the exhaust. Being a truck from the North I am sure there was some good rust in typical places.
Keep us posted.
I'm wondering how the outcome of this research has helped solved the problem. I too, have a seriously hot FZJ80 (96)....the passenger and driver's side are insanely warm - so warm, that my wife wont drive it- as it's quite uncomfortable!
I'll check the listed things above...and post up some results as to my findings on our LC.
Thanks for a helpful write-up!
ColoCruiserJeff
