I just purchased a set (5) of 315/75/16's of my LX450. I went from a set of stock LTX M/S (31's)
Here are my pre and post measurements: (all measurements in inches unless otherwise indicated)
Ground to top of wheel wells: (only have post install measurements)
Tire Diameter:
Front Wheel - ground to the center Hub:
Rear Wheel - ground to the center Hub:
Ground to bottom of running boards
Impressions (first 5 miles)
Acceleration: cannot tell much difference truck feels virtually the same.
Braking: Can tell a little difference here however my upgraded brake system has helped to compensate.
Handling: feels about the same around town. Steering feels the same. Not any heavier.
Ride: at very slow speeds (1-2 mph) I can feel the tires
audible noise: can tell they are there and the sound has picked up however not like your average redneck f250 with super swampers howling down the road.
Spare Tire: Does not fit in stock location b/c of panard bar. I may be able to remove the stock hitch and stuff it under there however I will most likely be ordering a stripper pole from Slee till I can afford an IPOR rear bumper and tire carrier. (This was not a surprise)
Spedo: I have a slee spedo gear that I will also be installing this weekend so I will post pre & post measurements of actual speed compared to GPS measurements.
Price: From Discount Tire (Alot) out the door. The
was not very happy.....
Would I buy again??? HECK YES
These bad boys look great and really take my cruiser from mild to full blown trail rig!!!
IMHO my rig now looks the part!!!
I will be going out this weekend to try out in the mud and off road. I will be posting a review later then.
Here are a couple of pictures.
- 39.25 front
- 39.75 rear
Tire Diameter:
- 34.8
- 14.5 - 16.5
- 14.5 - 16.5
- Front - 16 - 18
- Rear -16.5 - 18.5
- Front 8.5 - 6.25
- Rear 8.5 - 6.75
- LTX M/S - Avg 84 dB (RPM: 2050)
- KM2's - Avg 87 dB (RPM: 1850)
- Engine Idling measured at 67 dB (engine at temp other conditions the same)
- Just installed my Slee Spedo correction gear
- When traveling at 55 mph (GPS) spedo reads 52 MPH. (1850 RPM's) Before it was of by 6mph. Improved by 3mph.
- Took 10 minutes to install
was not very happy.....Would I buy again??? HECK YES
I prefer white lettering on the inside though.
