I'm what you'd call somewhat financially challenged. I got bills, a kid, and I'm not exactly making what I used to. So, sometimes "ghetto fab" is the order of the day. Hey, you get what you pay for...good and bad.
I've always liked those fancy rear drawer systems, but they have two things going against them:
a) They're too damned expensive. If I've got a choice between a rear drawer system and a ticket to Hawaii, I'm packin' my boardshorts and flip-flops.
b) I need the third row in sometimes.
I just needed something to clean up the back of the truck. Something I could put the everyday items in, like the tire repair kit, compressor, tools, fluids, spares, and various duffles and stuff that clutter up the area, and still have a flat surface to put things on. It would need to line up well with the backs of the rear seats when they are down, in case I wanted to eliminate using a tent and sleep on it when I go solo camping. It would need some anchoring points, so I could strap down the cooler or gerry can, or whatever. An added bonus would be if the thing could look halfway decent, or at least inconspicuous, at first glance. I'd like to have everything of value out of sight, if possible.
Oh, and it would cost less than $100.
I got out the measuring tape and started counting. Went to Home Depot, and bought a sheet of 3/4" plywood, one 2"x12"x12', and a blue quilted packing blanket. Cost: $53.29
Then, I went to Target and bought two plastic bins, 34"x16"x6", suitable for packing wrapping paper or some such nonsense and stowing under a bed. Total cost: $16.53
I cut the plywood in one 41"x57" sheet, then cut the 2"x12"x12' into three equal, 41" sections, and screwed them on so that they ran along the space just inside the wheel wells, then creating two equal sized 19" wide, 12" tall, 44" deep compartments. Spread the packing blanket over the top and voila, instant smuggle space, with room to sleep on top.
View with rear tailgate closed:
View with tailgate open:
View under blanket:
Two of these 6" tall bins from Target ($7.99 apiece) stack and fit very snugly into the compartment, with a little room to spare.
My plan is to do a couple of cutouts in the wheel well area, to fit the Gerry can, and to better utilize the space behind the wheel wells. I will also upholster the entire thing, using the packing blanket and a staple gun. I considered painting it, in case of fluid spills, but...well, I'm lazy. I will also put some kind of anchors, ie eye bolts or rings of some sort or another, to more easily strap things to the top.
View under blanket:
