The P.O. of my car said he re-geared my cruiser but was unsure of the ratio. Is there an easy way of finding the ratio without pulling it all apart?
You can also do it with a helicopter.
But seriously, the driveshaft/wheel rotation is the easiest IMHO...
Agreed, just disconnect your DS from the 3rd member, use some chalk/paint/sharpie/blood to mark a spot to use for reference, then count the rotations of the tire/hub.
60 mph at 2100 rpm
removing the DS makes turning the axle easier at the pinion...you can also do it with N/N in tranny and t-case.
There ya go. That's by far the simplest method, no?To be sure, just raise ONE rear wheel, put t-case in neutral. Rotate the wheel TWO FULL revolutions, and count the number of driveshaft revolutions.
