As promised here are the pics...
Here is the new gear (it came with a new o'ring too!
This is the VSS1 unit itself... ignore the sensor, the gear housing is actually a cable speedo housing (similar to the mini trucks) and the sensor screws into it on the A46DE... weird!
I didn't notice the little gold linkage piece in the middle of that pic oriented the wrong direction when I took the pic.... in any case, the small end goes into the gear housing.... pretty obvious once you have it apart. I don't know if the mini trucks has this piece though
New and old driven gears side by side:
It's hard to see in this pic, but you can barely see the speedometer drive gear.... it's a giant worm gear inside the tranny's extension housing. If you don't know which driven gear you need, you can count the teeth in the drive gear. I counted it just for grins and it was indeed 6 tooth. Sorry, it was hard to take this pic.
The new gear just pops right in and it went into the extension housing like warm butter!
What's interesting is, there's no clip to hold the gear in place like it is on the hilux/surfs... Another 10 cent part unneeded I guess since the gear has no where to go as you can see in the previous pic... there's a giant aluminum stopper to keep the gear from flying out in the A46DE.
You can see the actual hilux/surf speedo gear unit here (notice the clip):
Mechanical Speedo Correction Box - Install with Pics - YotaTech Forums
Accurate speedometer again all for a little over 20 bucks! This is WAY cheaper than either the electronic or mechanical correction boxes which costs around $100. Time spent to put this in is probably less than the more expensive alternative.
I drove my van around and went by one of those speed check signs, and it is reporting what I was expecting... the speedometer is accurate! I still need to get it GPS checked but I'm confident it's within 1/2mph accurate
Hopefully this weekend I will post a list of speedo gears so all of you can benefit from this cheap fix like I did
