RTH: rebuilt transfer making awful noise
Medford, OR
Yup, just got the truck back and already a problem. I was doing right around 60 just now going into work. Then the heard a short grind noise out of nowhere. It went away. Then it can back and got longer and louder. Now it's making some horrific noises and I don't have a clue at what it could be. The transfer stick is vibrating a lot and the noise seems to be coming from it. Nothing is leaking that I can see and I can start up just fine and put into gear fine.
Help!! What should I be looking at? Note, I have no tools on me :(
http://www.youtube.com/watch?v=nZPXYG_pzek
I would not drive it until you pull it and open it up. Depending on what is wrong it might ruin more parts the more you drive it.
WOW call a tow truck, that sounds awful. It almost sounds like it does when you try and put it in 4 low wile moving. Maybe a issue with one of the shift rails moving around. Unfortunantlly it sounds like damage has already been done.:doh:
Doesn't sound good. Did you make sure the shifter was not knocked out of 2HI? it sounds like the hi/low shifter is moving around. Crawl under and make sure the linkage is not bound up.
Dyno
Sounds like the linkage is not adjusted correctly and is holding the hi/low collar out of its correct position.
Dyno
Joey don't bother buying a lotto ticket with your s***ty luck you have ZERO chance of winning. My original offer still stands it sounds like the truck just hates you.
Dyno
Dyno
My luck I would buy the winning one and then lose the ticket.
So being as it passed smog does that mean $550? I guess I could settle for $500. Spike was generous enough to offer $500. Doesn't sound do bad right now.
Spike Strip said:
Have you tried to shift it in and out of 4wd ?
Nevermind - didn't reload page.
BUT - Reminds me of this video: At around 4:50
<a href="http://www.youtube.com/watch?v=FUwototHAc4">YouTube Link</a>
I'm not sure it's the same noise. I can definitely shift the transfer without an issue.
That's a cool link though. I need to watch all of them while I'm waiting for the tow truck.
Wow... Talk about pilin' it on!
:D
long shot
this might be too late but how about $575 and $5 quick pick ticket on mega milloins for tonite? i can get it this weekend i'm here in San Diego.:D
