Below is text from a thread, It lists the HF series fits behind the A440F and A442F gear trannys in 80 series. These transmissions are also used on FJ62. Does this imply the transfer cases use on FJ62 will also fit on A series trannies? Will a FJ62 tranny fit an FZJ80. Is there a list of transfer case to transmission compatibility.
Transmissions fit behind the following gearboxes:
HF1A - H150F, H151F, A440F, A442F
HF2A - H140F, H150F, H151F, A440F, A442F
