I got a little bored tonight and decided to see about adding an AC plug to my dash.
I had purchased an inverter a while ago but couldn't figure out where to put it. After staring at it I decided to take the faceplate off and I saw pretty quickly that the whole plug could be easily extended and mounted to any flat plastic surface.
After hunting on my dash a bit, I decided that the little removable panel under the radio would be the perfect spot so I went for it.
First things first, I took the old inverter faceplate off, disconnected the wires (using snips and a soldering iron) and cleaned them up.
face as she LOVES the weather. Keep up the good work. Any idea if you're coming to the round up?
