I got a Toyota TPS and set about installing it. I need some insight as I think my technique may be the issue/problem.
I have posted on here before, but I will run down the specifics:
Application: 3FE w/ block # 3F 017791x (hard to read the last digit). Based on
this block # I believe the 3F to be an early 1988 engine. It is tucked in my
1974 FJ55 Pig, complete with factory AFM, harness and ECU
Incident: Repeated episodes of loss of ability to idle once engine reaches
operating temperature. Check of the ECU diagnostic codes pulls Code 12 - RPM
signal and Code 41 - Throttle Position Sensor Signal. Clearing codes returns
the same results. I believe ECU is not getting valid signal to determine
throttle position AND RPM signal. I think this would make it difficult to
manage idle. New Car Features 1988 says ECU will manage engine as if throttle
is closed if it gets no TPS signal, but combined with no RPM signal, I don't see
how it could do this.
Resolution (attempted): Tried two prior TPS from Autozone - Duralast brand.
Installed as per FSM, but they would not check out as per page FI-69 in FSM.
Order Toyota TPS and pull Throttle Body to facilitate install w/ feeler gauges and ohmmeter.
So I set up my new, Toyota TPS as per page FI-70 in my FSM, using
-0.93 mm feeler gauge
-ohmmeter on IDL and E2 terminals
-turn sensor clockwise until ohmeter deflects from 0 ohms to some value less
than infinite.
-NOTE: my combo of feeler gauges is closer to 0.94 mm.
Then I check reading at VTA and E2 with no feeler gauge clearance btwn lever and stop screw. I am over the 6.3 k-ohm.
I then open throttle valve fully open with ohmmeter still on VTA and E2, my
reading is well over the specified 10.3 k-ohm. Closer to 40 k-ohm.
I go back to 0 mm clearance and decide to reset the TPS position to get
resistance less than 6.3 k-ohm. I set the TPS with resistance btwn 4 and 5
k-ohm at VTA and E2.
I leave ohmmeter on VTA and E2 and move throttle valve fully open and get
resistance value of about 40 k-ohm. WTF?!?
I decide to reset TPS position with throttle valve fully open to see if I can
get resistance value at VTA and E2 less than 10.3 k-ohm.
FAIL.
I clocked the TPS through the entire range of adjustment and can not get resistance value to move from approx 40 k-ohm.
What gives guys? Everyone says this is easy to do. So what am I doing wrong?
than infinite.
FAIL.
