So I have searched every possible combination of key words (including a forms of conversions saginaw, astro, scout, FJ60) as well as read every FAQ article I can think of to find an answer to my quandry with no solid answer.
I am in the process of converting my 1981 FJ40 from OEM to FJ60 power steering using a Flaming River DD slip shaft (approx. 3" of travel). My issues are with the stock steering column, specifically how to deal with the late model's two piece column. The rag joint section slips into a cross inside the column inside the firewall and protrudes to connect with the rag joint. It appears that the location of the stock steering box prevents the slip shaft from falling too far out of the cross.
Issue 1: When you remove the stock steering box, the shaft is able to move in and out 2-3". I'm not confident the fit of the bearing alone will prevent it from sliding down. I've thought of slipping a rubber grommet onto the shaft to limit the downward travel since it will butt up against the bearing installed in the column to support the shaft, or tack welding the bearing to the shaft, or welding a washer onto the shaft and putting a teflon washer between it and the bearing to provide a smooth mating surface.
*How have others secured the shaft to prevent this downward movement and keep the shaft up in the cross?
Issue 2: I was told my stock shaft may be too big
. I don't have it in front of me to mike out to compare to the 3/4" bearing's inner diameter. Does the Kilian F-350-89 bearing fit this shaft?
*I understand I may have to sand it a bit, but does it require more work, like having it turned down in a lathe?
Thanks for the assist!
. I don't have it in front of me to mike out to compare to the 3/4" bearing's inner diameter. Does the Kilian F-350-89 bearing fit this shaft? *I understand I may have to sand it a bit, but does it require more work, like having it turned down in a lathe?
