Hi,
I'm building up a set of Metaltech tube fenders. I've replaced the outer hoop with 1.5" .120 DOM, and am tying them in with the sliders at the rear of the fenders. I'd also like to tie them in at the front so the rig is tubed all the way around.
I'm wondering if I could do something like in the picture below. The purple line is supposed to run exactly on the outside of the front bib contour. My 40 is down to the chassis right now, so I can't see if my tires will rub or not. I currently have 35x12 MTRs but might go with 37s. I'm also planning on putting a 2" wheel spacer on each wheel. The front is SOA, so I expect the tire could get fairly close to the fender.
I tried mocking up a piece of cardboard cut to the size of a 37" tire, but I'm not sure how sharp you can turn the wheel on a 40. Does anyone know the maximum angle in degrees that you can turn the wheels on a 40, relative to the axle? Thanks.
