My 40 is consuming a lot of my time and the
is getting jealous.
Long story short, had to take off the alternator to replace a radiator hose. After I got done I tried to reconnect the +iv back to the battery, as soon as the connection was made, smoke came from the fusible link area (not sure if it was the link or the fuses). All fuses in the picture (two in the black box, one in the while tube) were blown as well, and of course no power when I tried to turn key. Tried replacing the fuses and reconnecting one more time and one of the black box fuse blew again... and here I am for help.
I have a three questions...
1 - What is the correct amp and purpose for each fuse? Since I tried replacing the blown ones I am not sure which amp goes where, know all three are different amps.
2- How do I test the fusible link? to check if it survived.
3- How do I troubleshoot this issue. I expect a short somewhere and here is some context... Between detecting a cooling issues and waiting for parts to arrive I grounded the idle solenoid... Parts arrived, changed the thermostat, fired her up, it ran for 10 minutes before I detected another leak, parked her back in the garage... Disconnected +iv cable, removed alternator, replaced radiator hose and put everything back together. When I tried to connect the battery cable back I experienced this new issues. So I am expecting solenoid or alternator wiring, or I might have messed up with some other wiring while trying to yank out radiator hose.
is getting jealous.Long story short, had to take off the alternator to replace a radiator hose. After I got done I tried to reconnect the +iv back to the battery, as soon as the connection was made, smoke came from the fusible link area (not sure if it was the link or the fuses). All fuses in the picture (two in the black box, one in the while tube) were blown as well, and of course no power when I tried to turn key. Tried replacing the fuses and reconnecting one more time and one of the black box fuse blew again... and here I am for help.
