Look what I just picked up for 400 bucks
Layton, Utah
www.hertzlayton.com
Just picked up some new (installed but never run he was Parting out his project)
OME 2.5" lift springs with bushings and bolts for 400.00 bucks
He was just 5 min from my house too!
Sounded like a deal so I jumped on it.
What do you think?
Cool you need the shackels tho
I made a similar deal a few years back The OME springs had been broken in but they came with brand new OME shackles and bushings for $350. Nice score!
You'll hate those...:D
So I'll do you a favor and take them off your hands.
You got an awesome deal. Hope they work out well for you.:cheers:
Great deal. Lift springs have more arch and thus are longer than stock as they flatten out. Longer shackles allow the springs to flatten out more during compression. Your springs will work better with the proper length shackles.
nice.... the front springs get the overload leaf? just curious why the shim is on those leaf springs.. shouldnt the shim be on top with the center pin reversed..
Saw those on KSL and knew it was a good deal. However, couldnt figure out how to get them down to me. verified price at cruiseroutfitters.com Good deal!
the guy I bought them from had a 78 and done a SOA and had the shim on the rear.
I will flip the center bolts around.
Will I / should I need to use the shim in the front?:hhmm:
Only if you use longer shackles and change your caster angle.
I needed to shim the front to restore the caster, stock length shackles.
