Colorado Boy-74-FJ40
I may grow older but I refuse to grow up!
I got my pics from my air rail removal. 14MM 1.5 pitch plug on the fender and pic of installed plugs. Note the blue high temp loctite. Drove it 2 days and no leaks noted.
True Value HardwareIanB said:Looks good, where did you source those plugs?
The plug on the fender and the ones installed in the head are the same ones. Hex head. As mentioned by the other poster, the injection is a 70's answer to emissions outputs, pumping air into the exhaust to keep emissions outputs down.WES1977 said:Question is that an allen head plug? In one picture it looks like one and the other with the locktight i cant tell. .
If you run out of options, I can get a set and mail them to you.projektdotnet said:what about cutting and filling the OEM's with weld material? (true value here didn't have em)
