G'day mudders,
Looking for some help (again) please. Took my shifter off to pretty it up, noticed a few bruises and having difficulty locating the correct part numbers.
In photo 1 - you can see some dents on the shift stick (on both sides from left-right movement). For a 26 year old I guess it is not bad, but what part is worn for it to do this?
In photo 2 - the tower dowels have some slight movement - should they be rock solid, will this contribute to the dents noted above? I'm guessing not?
In photo 3 - are all the parts I have taken out (except for the shift lever housing bush) and planning to replace if possible. Looking through toyodiy I am confused - for my truck with H55F 5spd it does not list the "spring lever spring seat" and it lists a "conical spring". Looking at the 4F on toyodiy, it lists the cap, spring, "spring seat" - but it does not list the "transmission shift lever ball seat" (I think it is the black rubber ring in the pic). (And looking at the SOR part number 062-77 I guess mine is cactus and the likely cause of the bruises to the shift lever?)
Hope this makes sense - any insights would be greatly appreciated. I need to order most of the parts from Japan so I am keen to make sure I get the right stuff.
