i have really wanted tilt steering in Rankenstein for a long long time so i thought this was going to be an easy mod and jumped right into it.. it didnt end up that way and i needed a little while to think about things.. i came up with this over the last week.. it was a pain in the ass but now that i have most everything worked out, i wont hesitate doing this again.. i hope you guys enjoy.
the "pocket" that gets bolted to the fire wall had to get the inside enlarged so the end of the steering column could get through.. the final hole ended up being cut around all 4 welded nuts in the pocket and resembled a cross.. this was so not only could i get the end of the steering column shaft through the hole but the u-joint from the column.. everything just squeeks through..
here is a little closer pic..
this is the template that i made using the base from the original steering column.. this will be the plate that gets welded to the end of the 60 series column..
this is the plate being built.. the 4 holes i think were drilled to 3/8's and the center hole was 2 inches..
this is the final product built.. i had to cut it in half so i could get it around the steering column end.. from here i put the 60 series column to where it looked like it would work and installed the two halves around the column shaft in the firewall pocket..
i will have to get a pic of what the steering column looked like before.. where the springs for the tilt column mechanism hook up, the whole area had a lot of excess metal that flared out making it tough to put into the stock colomn location in the firewall.. a lot of trimming was done to make this work and then that cross brace was rewelded.. this is a very much needed step to make this work.. this cross piece will also serve as a mount for the brake pedal return spring.. the original mounting hole was cut off when i enlarged the column mounting bracket..
you can see how much i had to cut out of the column support based on the shiny grinded metal.. i wasnt pleased with how low the column was sitting under the dash so i cut and trimmed in small doses till i was able to get it up enough to where it was in the stock columns location.. sorry, no before photos..
here is another..
and another..
here is the column removed again for final welding of my square base plate..
and another..
and here it is bolted up in its home.. i still have to sand blast and paint all the associated parts but i am still just test fitting everything at this point..
and one more from the inside.. although it doesnt look like much, its been a pain in the butt to get to this point.. i think that column has been in and out of the truck over 40 times..
and the result.. all the way down.
and all the way up..
here is another..
and another..
and another..
