My first cruiser, & I am going to build it...
A little background I have been building & wheeling mini-trucks & samurai's for more than 8 years. I consider my self some where between novice and intermediate fabricator...
Pictures of the victim, traded a guy a pretty clean solid axle x-tra cab for it... Bondo and all... Yes I know the grill is on upside down I'll fix it later right now its not a concern...
Correction a 77
Picked up a pair of FJ-60 axles, tore the front down immediately...
Cleaned up the housing so it would be ready for the cut & turn and spring over, also removed the diff studs because they looked pretty beat & ran a tap through the housing to clean up the threads....
Currently Redline has the housing doing the cut & turn, I have never done that so thought I would let someone who has done it more than once, do it right...
Then cleaned the knuckles up and bead blasted them, of course it had to sprinkle a little that day before I could pull them back into the garage. I'll hit them one more time...
Since I am still collecting parts for the spring over & Redline still has the front housing I am starting on another front.
Went to the junk yard and pulled a tbi wire-harness, throttle body miscilanious sensors, and ecm(1227747)... Wire harness as I got it home,
After two nights of working on it, removed every thing that isn't needed, and labeled it all up...
The excess...
I am awaiting Downey to get in another set of throttle body adapters (can't believe I am actually going to buy something from that company...)
Just ordered 4x4labs front frame reinforcement, also ordered a saginaw box (6529)
Correction a 77
The excess...
