hey guys.... have a question for all you "cruiser guru's"..
a quick history of the vehicle...
1975 fj40
has had a 350 chev conversion, with a 5 speed tranny conversion by PO.
i bought it around 2 months ago, and have started fixing the usuall problems ( decided to fix things first..so havent even had it off road apart from a quick check to see it worked..lol), and have done a disc brake conversion on the front end ( all new gear), replaced the brake master, clutch master...and the list goes on!!! ( you guys are right..they cost $$$...lol )
i just retuned the motor, as it wasnt running right...had started backfiring through the carb..and also was running on when i turned it off............ turned out the timing was way out... so re-set that...and it is running sweet as! only problem was the clutch was now slipping. so re-adjusted the slave to make sure it was re-leaseing properly..all good...
anyway, i had to do a job 300km away, so took the 40 and towed a small trailer...if i took it lightly..no slipping...but go anywhere near half throttle...instant slip.... not good.
returned home a week later ( no driving while away)..and awoke to gear oil on the driveway!! so dropped the gearbox/transfer case ( damn heavy buggers arent they! )...when i dropped the rear tailshaft...around 3 teaspoons of oil came out from the end where it joins onto the tailshaft brake thing..ah ha.... found the source i guess
can somebody point me in the right direction on how to fix this?? is it a case of remove the whole transfer case to get to the seal..or just the cover that holds the brake thingo on? is there a pic by pic "how to" guide anywhere??
also, on the clutch plate...spoke to my local guys in perth wa. seems i have a chevy flywheel, a standard clutch plate, and a standard pressure plate. they tested the pressure plate which was supposed to be 1500ft lb of pressure...it was making 1300... have a heavy duty bugga on the way rated to 2600ft lb.... so doubt i will have slippage again!!
anyway, here is a couple of pics....
the gearbox
rear view ( seems to be modded to suit the tailshaft handbrake? )
the area where the leak is...
i found somwhere before that tells you what to look for to determine what year your box is..but cant find it now ( arrg), but it seems mine is a 83 box built in june...number 2110 .
any adivice would be appreciated guys... thanks
luke
1975 fj40
the gearbox
luke
