rear sill
Whats the best rear sill to replace the area rusted beneath back doors in a 78 fj40? Do you need 14 or 16 gauge?
Newbie getting his 78 fj 40 painted
One quick comment on the rear sills. I bought one off ebay for around $50. It was nice heavy gauge steel. I didn't like it though because there was no center recess for the door striker (amb doors). I just looked at the CCOT site and it looks like their's has the recess ('75 and later). It's a little more money, but I ended up not using the ebay one because of that.
Cheers.
16 gauge should be fine. I made mine with 16g, and reused the U supports from my old one. I had to make it in a few pieces and weld together, because that's what I had left over and my brake was not long enough to do the whole width.
Here it is with out the ends, and salvged U supports.set in.
For the end corners, I had some matieral left over from replacing the corner outer panels.
On salvaging the U supports, I found that after I cut them out, to get the old channel off, it was best to place in the vice grip, and grab the remaining metal with vice grips and twist N pull.
Make one out of two inch square tube and a flat 2 inch piece of 1/4 inch steel, weld it up very strong and nice, Larry
