A couple of weeks ago I posted up about an intermittent problem I was having. When the drivers door was open the window would not work, when closed it worked, first thought was...
, I hate wiring problems.
I went to the stealership with a hope and prayer to ask if there was some sort of programming issue, not so lucky . While there, I decided to massage the wires in the rubber boot that goes from the body to the door and yep, the window quit working all together, luckily it was up.
Today I decided pull the door panel and see what was going on. Not seeing any noticeably easy problems, I ended up pulling the wires from the kick panel through the small holes in the body and door and this is what I found:
Turns out there is one wiring harness in the country and my cost was going to be almost $300. I ran a patch on the broken wire and taped up the cracked ones and everything is good to go for now.
, I hate wiring problems. I went to the stealership with a hope and prayer to ask if there was some sort of programming issue, not so lucky . While there, I decided to massage the wires in the rubber boot that goes from the body to the door and yep, the window quit working all together, luckily it was up.
