- Joined
- Sep 21, 2007
- Threads
- 233
- Messages
- 3,911
Hey guys, I need to find out which fuse turns on with ignition? Are there any unused fuse spots in the vehicle fuse box to which I can use an add-a-circuit so that I can wire in my blue sea fuse block?
uhm if you're adding that much stuff, run straight to the battery.
simple fuse blocks....HA!
LJ,
I get you are adding a blue see fuse block... but what for? I ran one directly to the battery from the rear... but I have a fridge and needed it powered 24/7. A pretty elegant solution that I will eventually install in the engine bay is this:
https://forum.ih8mud.com/merchandise-storefront/352802-auxiliary-fuse-relay-panel.html
Here is the thread I used when wiring mine. Maybe there is some helpful info for you in there.
https://forum.ih8mud.com/100-series-cruisers/86714-accessory-relay-always-power.html
I had a Hella 6 fuse block that I had 3 hot and 3 switched on. IIRC I took power from the seat for hot and radio for switched. Ran the block straight to the battery with a fusible link in the line.
hey loud, thanks for helping me with the LEDs for my interior, but once again I am thrown off by the sarcasm that may come from your comments lol
Is that pic really a pic of a simpler fuse block to install?
