Hi all,
as you may have noticed, the trunk ceiling light is quite pathetic. Finding something there in the dark without a flashlight can be difficult. I bought this LED strip from Dealextreme for 10 $ incl S&H:
DealExtreme: $10.44 12V 75-LED White Light Strip (50cm)
The difference in light output is like night and day.
I've installed it in about 10 minutes in the rear part of the ceiling, where there is a trim part that can be easily removed (just pull down and rearwards). The light strip is then held in place just by this trim, without the white plastic housing.
Connection is in parallel with the rear ceiling bulb, so that it works the same as this one, and routing the wire between the sheet metal and the ceiling trim.
The pictures don't really show the difference in ligh intensity, which is very big. And it draws only about 500 mA (6W).
I need to think about some translucent cover to make it more discrete, but for now it stays this way for my holidays.
