Steering Rack leak - Rubber bushes changed to aluminum
Kuwait
I've noticed that the steering rack boots were leaking a little after a friend noticed my leaky CV boots ( Thanks SALEH :D )
I took the 100 to a small shop and the mechanic said I'd need to replace all the boots and the steering rack bushes. He suggested to replace the stock rubber bushes with aluminum ones instead. It seemed like a good idea at the time so I agreed. I have my 100 back now with the new aluminum bushes. I haven't noticed any difference in steering so far. Is there any down side to aluminum bushes? are the rubber bushes meant to absorb vibrations etc?
any input would be appreciated.
siglo: Is this the bushing you refer to in your original post? This "grommet" as named in the FSM is where I now have 'slop'. I am wondering if this is the same part you had replaced or?
Anyone know if this "grommet" can be replaced without pulling the rack?
Thanks,
Dan
i had replace mine also with aluminum cause it is rubber and it is fixed from the manufacture and their is no spare parts !! every years spressomon the part u marked it many times i seen mine changed placed !!! i noticed only with 315s and i can feel it while reversing or turning i replaced it and now it is ok.
i believe the 100 series i can say most problems from the front like CV boots and steering rack and front diff bushing.
Where did you source the aluminum "grommet"/bushing? Or did you just have one machined?
This Australian company make them:
http://www.fulcrumsuspensions.com.au/fulcrumCat/
This appears to be the mounts for up to 08/2002 models and then I guess there is a change in the design and a different mounting style?
Wonder where the two smaller bushings and then the two metal bushings go?
This "grommet" seems like a strange thing to wear out. It doesn't move...I wonder what causes the wear???
I'm thinking for the two other frame mounting points (driver's side and center).
Basic difference should be the dampening effect. So much other dampening occuring throughout the chasis, you shouldn't really notice it. I agree, not sure why it wore out in the first place
A great deal of force is being placed on these bushings - side to side. I've replaced the mounting bushings on a Tacoma and a 4runner too with polyurethane. I think this is a common problem with IFS Toyota 4x4's and more likely to happen when you are pushing large tires around.
I should know soon enough:)
Can't wait for the post up on your results!
I'm on my 4th rack. You'd think I'd be into a Lifetime Part category by now. ???
At almost $900 (+ tax & freight) parts for the rack plus labor the, what appears to be, disposable steering rack syndrome is bothersome John. Is this the consolation prize for a 35" modded hundy that is actually used off-road? Discouraging!
Couple of things.....I'd have to look at the one I bought....I wanna say it I got it for $380 plus a refundable core fee and plus labor.
Yes, this is the trade off on 35's and a difficult owner who punishes the vehicle. It's also the price you pay for this quality steering (unlike the 80-series). I'll pay to have the better performance. At least I do't have to deal with SO MANY 80-series issues that nickel and dime one to death.
How can you say the 100 has better steering than the 80 when yo have gone through 4 steering racks?
1. Gone through 3 (on the 4th). What are wishing on me! :D
2. Performance and durability do not always go hand-in-hand. Steering of the 100 blows away the 80 though it obviously is not as durable. Two different topics my friend.
I'll take the performance (even at this price).
Another topic:
Off-road...the steering/power steering of the 100 BLOWS the 80 away. The 80's have a VERY hard time turning up and over ledges, especially if locked. You can sit and sit and not turn the wheel in an 80. Never happens in the 100 (not yet to me or my other 100 buddies). You turn the wheel and it turns (and easily). I'll pay for the added maintenance to have this benefit.
The reason the 80 stops to steer is that you have reached the limits of the hydraulics. If the 100 allows you to steer that means the hydraulics are stronger but the net result is you are either trashing the steering system or the mounting system. It does not make it better. It makes it easier for you to steer, but the system is being stressed beyond what it was designed for. You run the risk of the link breaking or bending as well.
If you put hydro assist on the 80 you will have the same steering as the 100. :D
Christo:
I was hoping you would take my baited hook :D.
How often have you seen this problem occur? And in your opinion does it make sense to use either a poly "grommet" or have an aluminum "grommet" machined to add durability? Or would you recommend sticking with the rubber OEM "grommet"?
Wanna go fish'n again sometime Christo? :D:D:D
Now I spoke about two things in one paragraph!
Yes, the hydro setup is better on the 100. That's the off-road deal and I said "another topic".
Apart from the power difference, the R&P steering on the 100 bests the 80 too.
Can we expand on this a bit further..........
I believe my rack is leaking, oil on boot one side, haven't pulled it back to investigate if this is the cause but I am assuming so as I don't have any leaks anywhere else that I can find.
I will have to get to it and I expect I will have to replace the SEALS and possibly the BUSHES in the rack cylinder end stoppers to fix the leaks and any wear or play in the end of the rack. These bushes I would expect to be made of a aluminium/bronze alloy of some sort, but they could be a rubber compound?
Is this what was done to your rack to fix the leak?
Others here have mentioned the replacement of the external mounting bushes of the rack, which I see as not having any connection with repair of the leak you experienced.
Were your MOUNTING bushes also replaced?
So Shotts, why have yours been replaced?
What was wrong with them and why weren't they repaired?
Were the seals leaking each time?
Were the bushes in the cylinder end stoppers U/S or was the rack shaft bent or corroded?
More info please
