Go Back   IH8MUD Forums > TLCAForum.com > Toyota Land Cruiser Association Forum > Clubhouse Corner > CO/WY- Horsetooth 4 Wheelers Cruiser Club
LinkBack (3) Thread Tools Display Modes
Old 03-19-06, 06:05 PM   #31
PabloCruise's Avatar
TLCA# 10713
Originally Posted by chalmic
TJ,
Nice detailed process.
Gracias Amigo!!!
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
CO/WY - Horsetooth 4 Wheelers Cruiser Club
<<CLICK HERE>> for my Tech Threads
PabloCruise is online now   Reply With Quote
Old 05-17-06, 09:34 PM   #32
TLCA# 10713
Update: Post Cruise-Moab '06
Well, I didn't get to wheel the 40 in Moab, but Kipper did, and the PS system did just fine! They wheeled Hells Revenge and Poison Spider
I wanted to try to get some sweet shots of the 60 PS being articulated, but since I wasn't there, my buddy O'Neil took the shot below.
After driving over to Moab, I think I need to check my caster and add a steering stabilizer. The steering is a little darty when I brake hard. I am guessing I do not have much caster and will need to add shims. I just hope the front flange won't get pointed down too far!
I'll post up the caster data ASAP.
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 05-19-06, 01:19 PM   #33
projektdotnet's Avatar
PM headed your way TJ
"Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety." -Benjamin Franklin
projektdotnet is offline   Reply With Quote
Old 05-26-06, 01:06 PM   #34
Owyhee Jackass's Avatar
Excellent detail on your write-up. I did the same thing on my 45 using Mark W's article in TT and his suggestion on the 55 u-joint. I've been happy with it. My wife prefers to drive the SOA 45 over the bonestock FJ55 JUST because of the steering. I'd add power steering to the 55, but want to keep the air pump too. I have a '73 F so my air pump isn't in the same spot. I do have a dual pulley...I just need to get creative like you did.
Dan
Endeavor to Persevere
Owyhee Jackass is offline   Reply With Quote
Old 06-22-06, 03:21 PM   #35
GSMTR Chair
Trollhole's Avatar
TLCA# 15077
Great writeup.
Marshall
Upstate Cruisers
Toyota part number lookup Click here!
Buying a Land Cruiser Guide
73 Fj55 Big Ugly
76 FJ40 ROTW Big Gay 2f Build
75 FJ55 My Build
93 FZJ80 stock everything and staying that way.
Old 07-03-06, 11:08 PM   #36
TLCA# 10713
Steering clearance while articulating
Thanks Y'all!
I finally got some pics of the clearance betwen the steering linkage and the leaf springs while flexing:
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 07-09-06, 09:20 PM   #37
TLCA# 10713
And a couple more
I just realized these show the steering pretty well while being flexed:
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 04-22-07, 11:09 PM   #38
TLCA# 10713
After dealing with light steering and negative caster for a while I threw in some 4 degree shims...
http://forum.ih8mud.com/40-55-series-tech/151088-death-wobble-after-adding-4-degree-shims.html
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 05-07-07, 06:22 PM   #39
TLCA# 10713
I just got back from Moab, so I drove the 40 ~900 miles. I think it drives much more nicely with some positive caster in the front end. It felt much more stable.
I feel like the positive caster puts more effort on the PS system - translating into more heat in the PS fluid. My PS pump was barfing when I worked it hard, so I will be adding a cooler soon. I thought it was just barfing out the top cap due to a weak gasket. I did see it spray some fluid past the front seal after some tight turns in the sand on Wipe Out Hill.
While in Moab I met someone who claimed to have found a replacement bushing for the Toyota PS pump. I will try to track that down and rebuild a pump.
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 08-26-07, 07:03 PM   #40
TLCA# 10713
Relay Rod
Since this write-up I have gotten a few inquiries about the relay rod on this project.
A quick review: I kept the 40 knuckles on the housing, so I needed a way to tie in with the 60 series pitman arm.
What we did is mate the 40 relay rod to the 60 relay rod with some splints on the outside of the two arms. The splints were notched to accommodate the different diameters.
I contacted CDan about a rebuild kit for the pitman arm end of the relay rod and found Toyota has upgraded the end - you have to buy the entire relay rod for a 60 series.
Here are the pictures:
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 08-26-07, 11:35 PM   #41
Thanks. Just what I needed to figure this out. Now if the parts would just get here.
Vic
Redlands, CA.
El Cazador is offline   Reply With Quote
Old 01-23-08, 01:14 PM   #42
67azcruizr's Avatar
TLCA# 18163
It might be a little late for some of you but a LH side 70 series TRE would do the trick without having to shorten the relay rod.
59FST FJ25
62FST FJ40
64HT FJ40
Sean
67azcruizr is offline   Reply With Quote
Old 01-25-08, 02:07 PM   #43
TLCA# 10713
That is awesome to know!
Do you know if US Toy dealers can order this? Do you have a good p/n?
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 03-02-08, 09:00 PM   #44
TLCA# 10713
Well, I have been talking about adding a PS cooler to keep the pump from barfing when it gets hot.
I also wanted to replace the stock 60 series high pressure hose with one that could be routed correctly in the engine compartment.
So I got a spare PS pump to rebuild and sourced a cooler. Then when went to see about getting a new high pressure PS hose made, I found it difficult to source custom made hose with metric fittings. Thanks to some posts by Mace, I found some adapters to adapt from metric to #6 JIC. I got two of those (one for the box, one for the pump) and away we went.
I like the resulting set up much better. The high pressure line is no longer running near the EGR and exhaust manifold. Now the low pressure side runs to the far side of the radiator to a cooler.
We will see how this does next time I am aired down and running tight turns in the sand!
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 03-02-08, 09:04 PM   #45
TLCA# 10713
First I rebuilt the pump using the FSM - nothing too tricky.
Just watch things when you tear the pump down. You don't want to loose the springs that ride on the slippers!
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 03-02-08, 09:07 PM   #46
TLCA# 10713
I cleaned everything and got a rebuild kit from CruiserDan and put the pump back together...
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 03-02-08, 09:10 PM   #47
TLCA# 10713
Reassembling the compressor portion of the pump takes some patience.
You will need to orient yourself to the rotating direction of the pump in order to correctly install the slippers
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 03-02-08, 09:14 PM   #48
TLCA# 10713
Here is the fittings used, the configuration of the high pressure hose to keep it as far away from engine heat, and the cooler I used.
On the new hose, I sourced a 90' fitting at the box and a 45' at the pump.
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 03-02-08, 09:19 PM   #49
TLCA# 10713
Here you can see the new pressure line routing vs. the old.
Also, take a look at the new PS pump cap that Toyota sells. You can no longer just get a replacement gasket for a leaky 60 series PS pump cap...
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 03-02-08, 09:39 PM   #50
TLCA# 10713
Can anyone comment on the length of a 70 series TRE and relay rod?
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 03-05-08, 04:22 PM   #51
Where's mah cruzah?
polarweasel's Avatar
TLCA# 17558
No, but I'd like to know what the cooler, fittings, lines, rebuild kit, etc. cost you. My 42's pump leaks a decent amount, and I've got a spare in a box that I'm sure needs to be rebuilt. Might as well add a cooler while I'm at it.
84 FJ60, locked and lifted and dismantled with Mercedes diesel
1982 BJ42 loud and slow daily driver on 33s
Horsetooth 4-Wheelers
polarweasel is offline   Reply With Quote
Old 03-05-08, 05:40 PM   #52
TLCA# 10713
PS rebuild kit from CDan runs around $40. I think the new style cap is ~$12? (Honestly can't remember)
The cooler is a ~$40 NAPA piece...
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
Old 03-05-08, 09:56 PM   #53
FJ40zen's Avatar
TLCA# 17588
Doesn't someone make a threaded tie rod insert that can be welded into the ends of a cut-to-length thread-less tie rod? Kept tight with a jam nut. I saw them somewhere in the last couple months... I think that would work great for you.
1978 FJ40
396 417 528 639 741 852 963
FJ40zen is offline   Reply With Quote
Old 03-13-08, 07:23 PM   #54
Where's mah cruzah?
TLCA# 17558
Yeah, the new-style cap is cheap and a very good thing. I've already got one of those, and it's helped keep the oil spray to a reasonable level. Guess I need to get ordering a rebuild kit, though. Thanks!
Old 03-19-08, 10:48 PM   #55
TLCA# 10713
Here is one better - custom made tie rod and relay rods for FJ60 ends - and they are local
Front Range Off-Road Fabrication
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
