Old 06-29-05, 01:12 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
drexx's Avatar
Post SERVICE SPECIFICATIONS, LUBRICANTS: Land Cruiser (FJ-, BJ-, HJ-, 60 & 70 series)
29Jun2005 (UTC +8)
Can this service specification make it into the FAQ? I compiled this because I'm consolidating my LC maintenance info and it's easier to reference now. If there are any corrections, please feel free to tell me about it!
* I got this info from geniune Toyota publications & service manuals. Though I have the Haynes, Max Ellery, Gregory's... I didn't consult them for fear of getting erroneous info.
Vehicle: Toyota Land Cruiser (FJ-60, -62)
Engine model: 2F, 4.2L inline-6 cylinder gas-engine
Engine model: 3F, 4.0L inline-6 cylinder gas-engine
Fuel type: 91 RON unleaded, 90L
Engine oil, 2F: API SF, 8L (with oil filter change)
Engine oil, 3F: API SF, 7.8L (with oil filter change)
Coolant: Ethylene-glycol based, 16.5L
Manual transmission (model H41): API GL-4 or GL-5, SAE 90, 3.5L
Vehicle: Toyota Land Cruiser (BJ-60, BJ-70)
Engine model: 3B, 3.4L inline-4 cylinder diesel-engine
Fuel type: 40 cetane number, 90L
Engine oil: API CC, 6.7L (with oil filter change)
Coolant, BJ-60: Ethylene-glycol based, 13.3L
Coolant, BJ-70: Ethylene-glycol based, 13.8L
Manual transmission (model H55F): API GL-4 or GL-5, SAE 90, 4.9L
Vehicle: Toyota Land Cruiser (HJ-60, -61, -70 series)
Engine model: 2H, 4.0L inline-6 cylinder diesel-engine
Engine model: 12H-T, 4.0L inline-6 cylinder turbo diesel-engine
Engine oil, 2H: API CC, 10.7L (with oil filter change)
Engine oil, 12H-T: API CD, 10.7L (with oil filter change)
Coolant, HJ-60, -61: Ethylene-glycol based, 15.4L
Coolant, HJ-70: Ethylene-glycol based, 14.2L
Vehicle: Toyota Land Cruiser (FJ-60, -73, -75 series; BJ-60, -73, -75 series; HJ60, -75 series)
Transmission, manual (H41): API GL-4 or GL-5, 3.5L
Transmission, manual (H55): API GL-4 or GL-5, 4.9L
Transmission, automatic (A440F): ATF Dexron II, 15L (dry fill) or 5L (drain & refill)
Transfer case (with H41 or H55F): API GL-4 or GL-5, SAE 90, 2.2L
Transfer case (with A440F): API GL-4 or GL-5, SAE 90, 2.1L
Differential, front: API GL-5 hypoid gear oil, SAE 80w90, 3.0L
Differential, rear: API GL-5 hypoid gear oil, SAE 80w90, 2.5L (use LSD oil for LSDs)
Power take-off: API GL-4 or GL-5, SAE 90, 0.5L
Winch, mechanical: API GL-4, SAE 90, 0.3L
Winch, electrical: ATF type F, 2L
Steering gear housing: API GL-4, SAE 90, 0.63L
Power steering: ATF Dexron or Dexron-II, 0.81L (total) or 0.390L (tank only)
Steering knuckle: Molybdenum-disulfide lithium-base, NLGI-2
Steering link ends: Molybdenum-disulfide lithium-base, NLGI-2
Wheel bearing grease: Lithium-base multi-purpose, NLGI-2
Propeller shaft: Lithium-base multi-purpose, NLGI-2
Brake fluid: SAE F1703 or DOT-3
Vehicle: Toyota Land Cruiser (RJ-70, -73 series)
Engine model: 22R-E, 2.4L inline-4 cylinder gas-engine
Fuel type: 91 RON, 90L
Engine oil: API SG, 4.3L (with oil filter change)
Coolant: Ethylene-glycol based, 11L (with fr/rr heaters)
Tranmission: API GL-4 or GL-5, 2.6L
Transfer case: API GL-4 or GL-5, SAE 90, 2.1L
Differentials, fr & rr: API GL-5, 1.98L & 1.85L
Power steering: ATF Dexron-II
Brake fluid: SAE J1703 or DOT-3
Vehicle: Toyota Land Cruiser (LJ-70, -73 series; KZJ-70, -73, -77 series; HZJ-70, 73, -75 series)
Engine model: 2L-T, 2.4L inline-4 cylinder turbo diesel-engine
Engine model: 1KZ-T, 3.0L inline-4 cylinder turbo diesel-engine
Engine model: 1HZ, 4.2L inline-6 cylinder diesel-engine
Fuel type: 48 cetane number, 90L
Engine oil, 2L-T: API CD, 6.7L (with oil filter change)
Engine oil, 1KZ-T: API CD, 8L (with oil filter change)
Engine oil, 1HZ: API CD, 9.5L (with oil filter change)
Coolant, 2L-T: Ethylene-glycol based, 11.5L (with fr/rr heaters)
Coolant, 1KZ-T: Ethylene-glycol based, 12L (with fr/rr heaters)
Coolant, 1HZ: Ethylene-glycol based, 11.6L (with fr/rr heaters)
Tranmission, 2L-T & 1KZ-T: API GL-4 or GL-5, 3.0L
Tranmission, 1HZ: API GL-4 or GL-5, 4.9L
Transfer case, 2L-T & 1KZ-T: API GL-4 or GL-5, SAE 90, 2.1L
Transfer case, 1HZ: API GL-4 or GL-5, SAE 90, 2.2L
Differentials (2L-T & 1KZ-T), fr & rr: API GL-5, 1.98L & 1.85L
Differentials (1HZ), fr & rr: API GL-5, 2.6L & 2.5L
Drexx Laggui - TLCA; 4x4PH
UZJ-100; FZJ-80L; FZJ-80; HZJ-80L; LN-166
Metro Manila, Philippines
Action and adventure pics!
UZJ-100W; FZJ-80L; HDJ-80L specs
drexx is offline   Reply With Quote
Old 06-29-05, 04:06 AM   #2 (permalink)
joel hj60's Avatar
Talking
Engine model: 2H, 4.0L inline-4 cylinder diesel-engine
Engine model: 12H-T, 4.0L inline-4 cylinder turbo diesel-engine
shouldn't these be 6 cylinders?
Excellent work my friend!!! very well indeed!!!
have one on me......
1985 HJ60
joel hj60 is offline   Reply With Quote
Old 06-29-05, 04:33 AM   #3 (permalink)
drexx's Avatar
Fixed it, many thanks for spotting it!
Old 06-29-05, 10:00 AM   #4 (permalink)
hks3sgte's Avatar
This should be a Sticky...
hks3sgte is offline   Reply With Quote
Old 06-29-05, 12:57 PM   #5 (permalink)
loeky's Avatar
TLCA# 15198
agreed.
maybe mike can create a sticky thread that contains general maintanance reference info, links and downloads with no chat, just posts.
thanks for doing the legwork drexx.
Matt N.
08 FJ Cruiser Sandstorm
87 FJ60 - SOLD
loeky is offline   Reply With Quote
Old 06-29-05, 02:20 PM   #6 (permalink)
IH8MUD Lifer - No Appeal
Mike S's Avatar
Drexx
Good stuff. I'll pop it into the FAQ...
Mike S
'96 FZJ80, locked, Hanna sliders, ARB bumper, Kaymar rear with spare carrier, 45 gallon Longranger aux fuel tank, OBA, Hella 4000's, OME lift, 285/75/R16 Revos & AutoHome Maggiolina rooftop tent, etc.
Custom Cruiser trailer with OverLand tent
www.AutoHomeUS.com
TLCA Member #14874
Mike S is offline   Reply With Quote
Old 06-29-05, 04:19 PM   #7 (permalink)
lowtideride's Avatar
TLCA# 14891
2fs take 91 octane??? eek hope not....good work brotha...
www.NFCruiserheads.org 2RZ-FE 'D 1983 SR5 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 06-29-05, 05:06 PM   #8 (permalink)
Turbo Diesel Lover
Tapage's Avatar
Someone using Castrol 20W-50 in 2H engines . ? recently changet from 15W-40 ( Castrol ) to get better oil pressure at low RPM ..
HJ-60 2H-T Intercooled Tencha
Old 06-30-05, 07:46 PM   #9 (permalink)
Sorry Dog's Avatar
91RON
translates to about 85 RON/MON average I think (however mine would ping like crazy on 85 in the heat)
Redneckistan, AL
89' 62 with 115k 2 dents, 2 leaks, and 3 dogs
Sorry Dog is offline   Reply With Quote
Old 06-30-05, 08:03 PM   #10 (permalink)
zcruiser's Avatar
Vehicle: Toyota Land Cruiser (FJ-62)
Engine model: 3FE, 4.0L inline-6 cylinder gas-engine, electronic fuel injected
Automatic transmission, A440F 4-Speed Automatic: Dexron II
Also found a cool Toyo tech article on Electronically Controlled Transmissions at http://www.autoshop101.com/forms/h17.pdf
SOLD: 1994 Red Pearl FZJ80, 202K, George's LEDs, PHH, etc.
1999 Millenium Silver 4Runner Limited, Toyo Open Country A/Ts
1993 Red Pearl 300ZX with some bling, K&N and a chip
Previous owner of sweet 1989 FJ62 with OME+KOs
zcruiser is offline   Reply With Quote
Old 03-04-06, 10:16 PM   #11 (permalink)
castrol 20-50
been using it for many years; excellent stuff; used to buy it in 55 Gal drums........brother in law who was one of exxons top lubrication engineers told me that exxon had never been able to surpass it, this was before synthetics but since the disasters of Mobil One in aviation engines 10 years ago have been reluctant to go synthetic!..........comments appreciated,
Lou
n2666s is offline   Reply With Quote
Old 03-05-06, 09:12 AM   #12 (permalink)
chicago's Avatar
TLCA# 16202
Awsome thread and info bro...just printed a copy off.
Thanks man,
Chicago
TLCA#16202, KE7VAT
Toyota family:
88 FJ62 (Sold to a good home. Goodbye old friend!)
76 FJ40 (Blotch rig part deux)
06 4runner...wifes rig!
06 Tacoma, DD, BONE STOCK and staying that way!
PROUD member of the WEST COAST BLOTCHERS and the Battle Born Cruisers of Northern Nevada!
FAWKING CUBS!
chicago is offline   Reply With Quote
Old 03-05-06, 05:35 PM   #13 (permalink)
Tinker's Avatar
6s -
Tell us more about the Mobil1 aviation disasters.
Porsche specs Mobil1 for all its engines, which is enough for me.
Tinker is offline   Reply With Quote
Old 03-05-06, 08:26 PM
Mike S
This message has been deleted by Mike S.
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/50283-service-specifications-lubricants-land-cruiser-fj-bj-hj-60-70-series.html
Posted By For Type Date
Offroad Forum CZ • Zobrazit téma - Jaký olej do LC BJ45? This thread Refback 06-05-09 01:44 PM
