SERVICE SPECIFICATIONS, LUBRICANTS: Land Cruiser (FJ-, BJ-, HJ-, 60 & 70 series)
Discussion in '60-Series Wagons' started by drexx, Jun 29, 2005.
  1. drexx
    drexx
    540
    4
    Sep 8, 2003
    29Jun2005 (UTC +8)
    Can this service specification make it into the FAQ? I compiled this because I'm consolidating my LC maintenance info and it's easier to reference now. If there are any corrections, please feel free to tell me about it!
    * I got this info from geniune Toyota publications & service manuals. Though I have the Haynes, Max Ellery, Gregory's... I didn't consult them for fear of getting erroneous info.
    Vehicle: Toyota Land Cruiser (FJ-60, -62)
    Engine model: 2F, 4.2L inline-6 cylinder gas-engine
    Engine model: 3F, 4.0L inline-6 cylinder gas-engine
    Fuel type: 91 RON unleaded, 90L
    Engine oil, 2F: API SF, 8L (with oil filter change)
    Engine oil, 3F: API SF, 7.8L (with oil filter change)
    Coolant: Ethylene-glycol based, 16.5L
    Manual transmission (model H41): API GL-4 or GL-5, SAE 90, 3.5L
    Vehicle: Toyota Land Cruiser (BJ-60, BJ-70)
    Engine model: 3B, 3.4L inline-4 cylinder diesel-engine
    Fuel type: 40 cetane number, 90L
    Engine oil: API CC, 6.7L (with oil filter change)
    Coolant, BJ-60: Ethylene-glycol based, 13.3L
    Coolant, BJ-70: Ethylene-glycol based, 13.8L
    Manual transmission (model H55F): API GL-4 or GL-5, SAE 90, 4.9L
    Vehicle: Toyota Land Cruiser (HJ-60, -61, -70 series)
    Engine model: 2H, 4.0L inline-6 cylinder diesel-engine
    Engine model: 12H-T, 4.0L inline-6 cylinder turbo diesel-engine
    Engine oil, 2H: API CC, 10.7L (with oil filter change)
    Engine oil, 12H-T: API CD, 10.7L (with oil filter change)
    Coolant, HJ-60, -61: Ethylene-glycol based, 15.4L
    Coolant, HJ-70: Ethylene-glycol based, 14.2L
    Vehicle: Toyota Land Cruiser (FJ-60, -73, -75 series; BJ-60, -73, -75 series; HJ60, -75 series)
    Transmission, manual (H41): API GL-4 or GL-5, 3.5L
    Transmission, manual (H55): API GL-4 or GL-5, 4.9L
    Transmission, automatic (A440F): ATF Dexron II, 15L (dry fill) or 5L (drain & refill)
    Transfer case (with H41 or H55F): API GL-4 or GL-5, SAE 90, 2.2L
    Transfer case (with A440F): API GL-4 or GL-5, SAE 90, 2.1L
    Differential, front: API GL-5 hypoid gear oil, SAE 80w90, 3.0L
    Differential, rear: API GL-5 hypoid gear oil, SAE 80w90, 2.5L (use LSD oil for LSDs)
    Power take-off: API GL-4 or GL-5, SAE 90, 0.5L
    Winch, mechanical: API GL-4, SAE 90, 0.3L
    Winch, electrical: ATF type F, 2L
    Steering gear housing: API GL-4, SAE 90, 0.63L
    Power steering: ATF Dexron or Dexron-II, 0.81L (total) or 0.390L (tank only)
    Steering knuckle: Molybdenum-disulfide lithium-base, NLGI-2
    Steering link ends: Molybdenum-disulfide lithium-base, NLGI-2
    Wheel bearing grease: Lithium-base multi-purpose, NLGI-2
    Propeller shaft: Lithium-base multi-purpose, NLGI-2
    Brake fluid: SAE F1703 or DOT-3
    Vehicle: Toyota Land Cruiser (RJ-70, -73 series)
    Engine model: 22R-E, 2.4L inline-4 cylinder gas-engine
    Fuel type: 91 RON, 90L
    Engine oil: API SG, 4.3L (with oil filter change)
    Coolant: Ethylene-glycol based, 11L (with fr/rr heaters)
    Tranmission: API GL-4 or GL-5, 2.6L
    Transfer case: API GL-4 or GL-5, SAE 90, 2.1L
    Differentials, fr & rr: API GL-5, 1.98L & 1.85L
    Power steering: ATF Dexron-II
    Brake fluid: SAE J1703 or DOT-3
    Vehicle: Toyota Land Cruiser (LJ-70, -73 series; KZJ-70, -73, -77 series; HZJ-70, 73, -75 series)
    Engine model: 2L-T, 2.4L inline-4 cylinder turbo diesel-engine
    Engine model: 1KZ-T, 3.0L inline-4 cylinder turbo diesel-engine
    Engine model: 1HZ, 4.2L inline-6 cylinder diesel-engine
    Fuel type: 48 cetane number, 90L
    Engine oil, 2L-T: API CD, 6.7L (with oil filter change)
    Engine oil, 1KZ-T: API CD, 8L (with oil filter change)
    Engine oil, 1HZ: API CD, 9.5L (with oil filter change)
    Coolant, 2L-T: Ethylene-glycol based, 11.5L (with fr/rr heaters)
    Coolant, 1KZ-T: Ethylene-glycol based, 12L (with fr/rr heaters)
    Coolant, 1HZ: Ethylene-glycol based, 11.6L (with fr/rr heaters)
    Tranmission, 2L-T & 1KZ-T: API GL-4 or GL-5, 3.0L
    Tranmission, 1HZ: API GL-4 or GL-5, 4.9L
    Transfer case, 2L-T & 1KZ-T: API GL-4 or GL-5, SAE 90, 2.1L
    Transfer case, 1HZ: API GL-4 or GL-5, SAE 90, 2.2L
    Differentials (2L-T & 1KZ-T), fr & rr: API GL-5, 1.98L & 1.85L
    Differentials (1HZ), fr & rr: API GL-5, 2.6L & 2.5L
    WanderinWhitlows likes this.
  2. joel hj60
    joel hj60
    119
    Apr 13, 2005
    2300, AUSTRALIA
    Engine model: 2H, 4.0L inline-4 cylinder diesel-engine
    Engine model: 12H-T, 4.0L inline-4 cylinder turbo diesel-engine
    shouldn't these be 6 cylinders?
    Excellent work my friend!!! very well indeed!!!
    have one on me...... :beer: :beer:
  3. drexx
    drexx
    540
    4
    Sep 8, 2003
    Fixed it, many thanks for spotting it!
  4. hks3sgte
    hks3sgte
    2,510
    Media:
    1
    4
    Apr 1, 2004
    Los Ángeles, CA.
    This should be a Sticky...
  5. loeky
    loeky
    634
    5
    Mar 24, 2005
    san francisco
    agreed.
    maybe mike can create a sticky thread that contains general maintanance reference info, links and downloads with no chat, just posts.
    thanks for doing the legwork drexx.
  6. Mike S
    Mike S
    2,537
    8
    Aug 19, 2003
    Drexx
    Good stuff. I'll pop it into the FAQ...
    Mike S
  7. lowtideride
    lowtideride
    7,596
    Media:
    12
    69
    Sep 29, 2003
    The Sunshine State
    2fs take 91 octane??? eek hope not....good work brotha...
  8. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    21,750
    547
    Apr 4, 2003
    Panamá
    Someone using Castrol 20W-50 in 2H engines . ? recently changet from 15W-40 ( Castrol ) to get better oil pressure at low RPM ..
  9. Sorry Dog
    Sorry Dog
    110
    Sep 24, 2003
    91RON
    translates to about 85 RON/MON average I think (however mine would ping like crazy on 85 in the heat)
  10. zcruiser
    zcruiser Needs monitoring
    1,202
    8
    May 7, 2005
    Hillsborough, NC
    Vehicle: Toyota Land Cruiser (FJ-62)
    Engine model: 3FE, 4.0L inline-6 cylinder gas-engine, electronic fuel injected
    Automatic transmission, A440F 4-Speed Automatic: Dexron II
    Also found a cool Toyo tech article on Electronically Controlled Transmissions at http://www.autoshop101.com/forms/h17.pdf
  11. n2666s
    n2666s SILVER Star
    2,622
    6
    Feb 21, 2006
    castrol 20-50
    been using it for many years; excellent stuff; used to buy it in 55 Gal drums........brother in law who was one of exxons top lubrication engineers told me that exxon had never been able to surpass it, this was before synthetics but since the disasters of Mobil One in aviation engines 10 years ago have been reluctant to go synthetic!..........comments appreciated,
    Lou
  12. chicago
    chicago
    9,612
    Media:
    21
    24
    Jan 18, 2006
    Reno, Nevada
    Awsome thread and info bro...just printed a copy off. :idea: :beer:
    Thanks man,
    Chicago
  13. Tinker
    Tinker
    2,862
    3
    Apr 15, 2004
    Larkspur, CO
    6s -
    Tell us more about the Mobil1 aviation disasters.
    Porsche specs Mobil1 for all its engines, which is enough for me.
  14. ditidahtkitesurfer
    ditidahtkitesurfer
    278
    1
    Jun 23, 2009
    So I've got a 2h in my hj60, and i've tried putting in 10.7 litres of oil and it has 2x in a row been two much. I suppose i should have noticed the first time. I think mine is taking roughly 7.5 litres of oil. Just an fyi for everyone looking at this...
    Question: does anyone know how much fluid the auto transmission takes on the hj60---the a440. Thanks.
  15. Biche
    Biche
    720
    Mar 26, 2011
    Mirabel, QC
    As per the FSM:
    Drain & Refill: 5 Liters
    Dry fill: 15 liters
  16. Ambrew
    Ambrew
    820
    48
    Nov 13, 2007
    Ontario, Canada
    Great thread!
    The h55 transmission has brass in itl. Some ep additives in gl5 "corrode" the brass over time. Newer oils can be "buffered" to reduce or eliminate this. It's worth looking into, even thought the manual does state gl5 can be used.
  17. ghisguin
    ghisguin
    56
    Dec 12, 2013
    Quebec Canada
