Hi everyone, i just brougt a 92 fj80 and replace the tires with 15" steel wheels and A/T tires. What tire pressur should i run them on the street? Mud? Sand?
If you can provide the following information, I can tell you exactly what pressure to run on the street and recommend pressures for off-road use:
1. Recommended tire pressure on your door jamb sticker Front/Rear
2. Recommended tire size on your door jamb sticker including whether P-Metric or LT (Light Truck) size and Load INdex (e.g. 112, 114, etc.) if known
3. Size, Load Range (e.g. D, E, etc.), and Load Index (e.g. 114, 121, etc.) of your new tires and whether P-Metric or LT size
4. Front axle GAWR from the sticker on your door jamb
5. Rear axle GAWR from the sticker on your door jamb
An added bit of info would be a picture of your door jamb sticker that corresponds to this one:
<snipped for brevity>
HTH
What math are you using to figure out the right pressure? Curious to see if I've been pretty close on the M/Ts I've been running and figure the best pressure for the A/Ts that are on the Tacoma wheels I'm wanting to use.
Forget the 31" tires, i just got some BF Goodrich KM2 33x10.50R15.
The LC weighs 6650 lb, front tire is 29psi, Rear tire is 41psi. Original tire is 29".
I called BFGoodrich but they couldn't help me out because if the front being so low. I put 38psi in all 4 tires now.
Factory info on my toyota fj80 landcruiser
Weight 6525 lb
Tire P235/75R15
Cold PSI 29 front (3305 lb)
Cold PSI 41 Rear (3970 lb)
I have km2 33x10.50R15 on the lancdruiser now
What if the tires have belly look alike on the sidewall? Is that still okay? With 38 psi the tires have a little belly on the sidewall already? Thanks for your help i will try it out.
I'm using the Load Limit/Tire Pressure tables and guidelines published by the Tire and Rim Association, Inc.
Using these tables one can determine the factory recommended Load Limit for the stock tires at stock pressure. From there, it is easy to calculate the pressure required to have the same Load Limit for a tire of a different size. There is even an easy calculation for substituting a LT tire for a P tire.
For example, my 2013 LC200 has a recommended tire pressure F/R of 33/33 psi.
The stock tires are P285/60R18 114V. The Load Limit @ 33psi for those tires is 2,520 pounds. Since these are P-Metric tires used on an SUV, the Load Limit was increased by 10%. The "raw" Load Limit is therefore 2,520/1.1 = 2,291 pounds.
The larger of 1/2 the GAWR (Front or Rear) can be no more than 94% of this "raw" Load Limit. My Rear GAWR is 4,300 pounds, so 4,300/2 = 2,150 pounds which is 93.8% of the "raw" Load Limit.
OK so far?
So if you want to substitute a different size P-Metric tire, you must find the Load Limit/Pressure that results in 2,520 pounds.
Since LT tires do not have to have their Load Limits increased by 10%, if you want to substitute an LT tire, you must find the Load Limit/Pressure that results in 2,291 pounds.
In my case, this resulted in going from a P285/60R18 114V tire @33 psi (Factory recommended size and pressure) to a LT285/70R17E 121R tire @ 40 psi.
So ... if I have the information I requested in my previous post, I can look up the values on the Tables and give the recommended tire pressure for the new tire.
Clear as (IH8)mud, right?
Trying to see if I'm doing the math right for these "new" Wintercats I've got.
Last set of stock sized tires I had were P225/75r15 XL, which had a max load per tire of 2094lbs @ 50 PSI (spec'd on the tires)
Door sticker shows GAWR for the front of 2785 lbs @ 26 PSI, GAWR for the rear of 3685 lbs @ 41 PSI
So since the originals were P-metric tires, the "raw" load limits would be
2785/1.1 = 2532 front (rounded to nearest whole number) and 3685/1.1 = 3350 rear
(2532/2)/2094 = 60.5% the original tire's load limit for the front
(3350/2)/2094 = 80% of the originals' load limit for the rear; well under 94%. I assume these checks are to ensure that the load limits set by the manufacturer aren't too close to the tires' maximum load limits.
So I want to find the pressure for my Wintercats that puts the front pair at a 2532 lb load limit and the rear at a 3350 lb load limit.
The Wintercats I have are E rated and have a max load rating of 3195 lbs @ 80 PSI
(2532/2)/3195 = 40% (rounded)
(3350/2)/3195 = 52%
So based on this I want the fronts at 40% of the max PSI and the rears at 52% of the max PSI.
80 * 0.4 = 32 PSI front
80 * 0.52 = 42 PSI rear
This is based on what the factory would recommend for these tires, but given how low the PSI of the front tires is, that just doesn't sound right. 42 PSI sounds like a good pressure though, given the max ratings for these tires.
And did I even do the math right?![]()
Well ... you're kind of on the right track, but you went terribly wrong when you assumed Load Limits are linear and that they are based on the Max Load/Pressure ratings.
Your stock P225/75R15 XL tires have the following Load Limits:
Front: 1,631 pounds @ 26psi
Rear: 2,028 pounds @ 41psi
If you are replacing this tire with an LT tire, then we need to find the pressure that yields the following Load Limits:
Front: 1,631/1.1=1,483 pounds
Rear: 2,028/1.1=1,844 pounds
To determine this, I need the size of your LT tires.
All of these Load Limits are derived from the Load Limit / Pressure tables published by the Tire and Rim Manufacturer's Association and are not calculated.
So give me the size of your LT tires, I'll look them up in the tables, and will let you know the recommended pressures.
HTH
