Zerorust as body paint?
"the whale's vagina", CA
I was looking over the zerorust website and the colors they have:
http://www.zero-rust.com/zero-rust-colors.html
I am contemplating the benefits vs. the downsides of painting the FJ55 project body I have in Zerorust colors. I plan to do a 2 tone with red/white factory paint. I am not looking for a perfect paintjob and kinda like the satin finish I have seen of some zerorust pictures when searching. I did not however find any threads specifically on using zerorust as a body paint. I have used zerorust on my fj40 frame and undercarriage and it has worked well. I was wondering if anyone else has done what I am describing and if so please post pics of the end result. Would the red oxide or safety red be closest to the factory color? Are there any downsides to using zerorust as a body paint?? I am expecting it not to be as glossy as your normal automotive paint but think it may be easier to apply here in my garage and I have experience with it. Also the FJ55 is not going to be a show car, It will be clean but I want to use it and it will be hauling kids (in the future) to the beach, desert, mountains, etc and I don't want to worry about every branch or pebble hitting it in the future. I would use the crystal coat on top of it for UV protection. Any and all opinions are appreciated. Sorry for all my retarded auto body questions lately as I am a total novice in this area, :)
Noah
I use it frequently but I must say that it is quite soft and will not stand up to the everyday bumps and bruises you will expect it too. I have not tried painting over zero-rust but that might be a solution. I would expect that you would need to wait a long time before painting over the ZR, so that it has time to cure first.
I painted my m416 in zero rust tan and the chassis in black. It's only soft til it's done curing and with a high solids content it takes a long time. Mine it still fine but I shot a several coats of clear acrlyic protectant over it for uv as recommended by them. I'm happy with their products and results. :cheers:
I dunno if I would paint my 40 the same way though. I'd probably just buy some half decent single stage and be done with it. See Treeroots 40 repaint.
I almost left mine in ZR. It looks pretty good all by itself. The nice thing is that it is easy to recoat if it gets buggered up. You can also top coat it later with a urethane or enamel. If you get enough coats on it you can even block sand it before top coating. ZR is a great preventive. If you don't have the $ to paint the truck with a high quality automotive finish, ZR it and it will keep till your ready for a better finish. The longer you wait the better, because ZR takes a while to cure.
