[quote author=Junk link=board=2;threadid=7179;start=msg59611#msg59611 date=1068095513]
Uh, you're going at least 38" right?
I think Pimp has Yukons, but I could be wrong. I'm sure he'll stick his fugly head in here. Not so sure how I'd feel about strength of the 5.29's though. That may not be an issue, but I thought someone had issues with these before with only like 37's or smaller on. :-[
[/quote]
You can have issues with any gears. Recently broke a Toyota oem set of 4.88's on the truck with 35's. I run 5.29's (Yukon) on the ShortBus.
We used to use Yukon, but due to quality issues we have dropped them for now until they have sorted out a new supplier. FWIW, Yukon is just the house brand for Randy's and Precision is the house brand for Reider Racing. Precision does not come in 5.29's. We have done a couple of sets of Precision and were happy with it.
As for third member rebuilt. Anything with more than 70k miles, you might as well replace the bearings. Not that they are worn, but if you try to get them of the carrier and off the pinion, they might get damaged. If you calculate the time in to do this, it is easier just to regear with new bearings.
No need to remove them off the carrier when doing factory locked diff, so sometimes you can re-use the carrier bearings, and only replace pinion bearings.
[/quote]
