Yet another wiring question or two.
Hiding
Okay I ll try to make this short and sweet. THis is a 1970 FJ 40 with the wiring harness coming from both driver and passenger side. If it makes a difference only the FRONT SIGNALS ARE wired in. The backs are gone and I have not checked any wires past the gas tank.
My headlights are still dim. I think as some have suggested here, there is a bad ground,
Can someone tell me where the two WB wires run back from the headlights to ground out to. are they in the dash or somewhere else.
Also. I replaced all the bulbs in the dash and side lights this weekend after making the proper connections. This is what happened in order.
Pull the lights on, Head lights come on, but are dim on low beam. Both Front and rear side lights work,
I then cut out the old flasher relay and wired in a standard two prong one. Hit the left signal, and I hear it clicking and the signal is working. hit the right signal and its working.
I plug in the indicators behind the dash. The right grounds and now flashes. The left I cannot seem to ground in the dash, When I ground it manually it does work and blink.
Now problems. When I have the lights on and the signal in left or right position they no longer blink?
I start the truck. Lights are a little brighter (still very dim) but now. the right front signal is stuck on. and both blinkers are no longer working. I check and there is no power getting to the blinker unit?
What gives. If its any help my Alt meter is pegged at +30 when the engine is running.
Any suggestions would be great, Is is possible to blow a blinker in like 30 seconds?
Thanks again, Warren.
Your blinkers are a complete circuit, and require both front and rear to operate properly. If you have lots of bondo/crud/corrosion on the front fenders where the blinkers mount, you won't get a good ground thru the blinker. All white with black stripe wires on your cruiser are ground. You can easily run a direct ground to body or battery from your headlights. Chances are you have 12v easily, just ground problem as mentioned. Either splice or cut the ground wire and ground it directly. Your early blinkers ground directly to the fender, sand, clean, etc., connect the rear two and try again.
Well that helps. I wonder why the worked (just the fronts) for 30 seconds, then when I fire the engine it stops. Where the confusion lies is that there is no power is getting to the blinker even from the relay.
I will attempt to remove the front signals and clean them up. They are definately corroded.
If your amp meter is pegged and does not come down you may have a bad battery or you you have a short somewhere. Something is putting a serious amp draw on the system. That may be part of the reason your headlights are weak.
I just looked at my harness for you. The DS WB wire follows the harness back and attaches to the screw on the voltage regulator that the alternator WB wire also attaches to (inner aspect). The WB on the Passenger side stays in the harness and goes through the firewall into the cab. I think it exits and grounds on a bolt on the passenger side, but I haven't taken apart this harness to see for sure.
That said, I agree with Lashcat, about the pegged ammeter. You have a bigger problem there and you need to deal with it first. Either you have an unwanted ground, bad switch or bare wire touching, or a dead battery, but probably both. I'd start with a fresh, charged battery (charge it unconnected to your vehicle wires). Then, all fuses pulled and everything turned off. Add back things one by one until you find what circuit is stealing power when it isn't supposed to be on.
http://tinyurl.com/47zpb Goto page 5,5A and 6. This details all the grief my turn signals caused me. 5A has all the wires on the fenders identified for you. Ground is your problem. Your best friend is a Dremel tool with a wire brush attached.
Thanks for all the suggestions. I am pretty sure the battery is charged, as it cranks over the engine just fine. I will get it charged though at the auto parts store. I know I have the WB wire from the passenger side in the regulator. BUT I dont know how good of a ground the regulator has to the firewall. I will clean that off. I also need to double check the alt ground. As the motor is a transplant. this is something I could have buggered up.
I have wirewheeled most of the body grounds, like for the side marker lamps.
Solved!!, It was indeed a bad ground. After I un taped the harness I started one wire at a time. Funny. Maybe this will help someone.
I stuck my tester light on the + of the batter and then probed several areas to see if there was a good ground. The bib was grounded well by the bolts that hold it to the fenders. I tried the triangle headlight slots. Ground= nothing. Then I switched the tester to - post of battery and turned headlights on, low was very low. high was better. I cut the ground from the passengers side harness and grounded it to one of the bolts that holds the bib to the fender. Turned them on and boom. Nice Bright headlights.
Now on to the turn signals!
So the ground wire attachment in the cab on that side must be corroded or loose.
Did you figure out your pegged ammeter?
Nothing on the ammeter at this time, I had the truck running and literally touched the bottom fuse on the block and engine died. Popped the 25 amp fuse I had right from the +battery post. Put in a 20 amp, pop, put in a 15 amp pop.
Im out of fuses, so the truck goes back in the garage until next weekend when I can get to it again.
Any thoughts, The fuse block is only attached to firewall with one bolt at this time. I had to relocate it some for the newer linkage gas pedal.
I also check the ground on my driver turn signal, it was shot, and fully corroded. of course attempting to remove the nut snapped it and the post, so I need a new turn signal housing. at least the part that bolts to the fender.
There are some fawked up wires on the rear harness where the PO had wired a trailer pig tail. those are getting cut out next time.
I still have no power going to either of the two wires for the blinker relay. (where as I did last week) Checked all the fuses, it just stopped working??
I had a problem with one of my fuse boxes where the insulation under the fuse clip on one side (headlight fuse) had cracked. It would ground intermittantly and blow the fuse. Solution was to get a new fuse box.
The bottom fuse should be your turn signal fuse, so of course if that is blown your flasher won't get power.
The bottom fuse should also have a wire (WR) that goes to the IG terminal on your voltage regulator, and off of it is a branch that goes to the speedmarker B terminal. I don't remember if you have your speed marker or not, but if it was removed and the wire is floating around and grounding, that might be part of your problem.
I am pretty sure that the fuse box is not intended to be grounded, just mounted, so I don't think one bolt is a problem, unless it causes something else to wiggle.
I dont have the speed marker but its possible that wire is off in space. The bottom fuse wasnt blown. So I will have to trace it back and see where the problem is. Damn thing, I would be fine if it never worked (blinker) and I had to fix it. But working for a while then not is not playing fair:)
The fuse block is in good shape, I took it out and completely cleaned everything, nice contacts and such.
