Yet ANOTHER tire/wheel thread!!!!
Irvine, CA
Sorry for the dumb question. And yes, I've searched through the forums but haven't exactly found an answer:
Locally (SoCal) there's a shop selling Nitto Dune Grapplers at 305/70/16 for $130 each. Nitto states the range of the tire is a 8-10" rim, so I know that the stock wheel does fit. But with my stock rim at the lowest end of that range, will this tire wear funny/unevenly? Or is anything in the range a "healthy" fit?
Of course, the shop said "no no no, it'll be just fantastic", but I trust the conventional wisdom here MUCH much more than the tire monkeys.
Should have no probs at all. I have run many tires on the bottom end of the rim size spectrum. If they didn't want you to use the 8" rim on their tires they wouldn't have even mentioned it in the specs. Besides Tons of guys are running 305's on stock cruiser rims without incident.
The center of the tires will be SLIGHTLY worn more than the outside, that's it. Nitto A/T tires are one of the best A/T's out there.
Wont even do that. The tire mfg. recommendation for rim size is ALWAYS the best to use. Since the range is 8-10, I would assume that a 9" rim would be perfect with 8 and 10 being just as good.
Only thing the 8" will do to your tires is keep them on the wheels better than a 10" would at low psi.
Yes, it will and does. I used to run BFG M/T 305/70 on 8" wide wheels and the center of the tires were more worn than the outside, not visibly though.
Recommendation is what it is, Recommendation. I do not see a narrower wheel can spread the tread better than a wider one. Are they usable, sure, but not identical in performance. Not even close.
And provide some rim protection, also pulls the sidewall in lessing the chance of it getting cut/damaged.
You weren't running at the right PSI. 33x12.50 BFG ATs on a 15x7.....30psi.....perfect wear pattern. Depth gauge verified.
Yes, but you haven't read the FAQ. The tire pressures shown on the FAQ are ALWAYS the best :flipoff2:
