yet another newby w/ a question
spring, tx.
Hello everyone, I'm the proud new owner of a 1996 locked 80 w/ 154k on the clock. It's dark green(is there any other color?) and is in great shape other than the leather. PO just fixed the EGR prior to buying and appears he had taken very good care of it. The only thing I've noticed is a very slight oil leak....I took it in today to have all the fluids checked and the radiator flushed and the mechanic said it appears that it is coming from the distributor o-ring. Just wandering if this should be a major concern or is this pretty common and a fairly simple fix? I'm not a great mechanic but look forward to learning on my 80, especially with the help of you all...thanks in advance for all that you for rookies like me who need help! Will post pics soon:D
That would be 6M1. I am so sorry for you.
,,, appears that it is coming from the distributor o-ring. Just wandering if this should be a major concern or is this pretty common and a fairly simple fix?
A dizzy O-ring oil leak is not a common problem but it should be an easy and cheap fix. Be careful to mark the dizzy before you remove it and get it back in the exact same location. I have one on the work bench and can snap a picture if you need it.
-B-
thanks guys, sorry about the lack of sig line.......Beowulf it would be great if you could post that pic.
