Yet another newb with a question
Vancouver, BC
Hi everyone, I have to say this is an awesome place for information.:popcorn:
I got a 97 lx450 a month ago and I noticed that the steering is a bit heavier than my mom's 97 lx450. I also noticed a soft clicking noise on sharp turns.
Is it a bearing issue? repacking? are these two symptoms related?
I'd love to hear some responses from you fellow mudders.:beer:
Mud Welcome! :flipoff2:
Pics of your truck will be necessar.
Regarding your 'clicking' do a search on birf's or front knuckle. How may miles are on your LX? It sounds like you are in need of a birf repack.
You'll also find lots and lots of info in the FAQ section. Read to your hearts content. The moderators have done an excellent jog of accumulating the wealth of maintenance and modifications to our trucks there.
only 153,000km, so just under 100k miles
Welcome! It does sound like birfs..that is the first place I would look.
Here is the picture of my LX and also some pics of the front axle.
From one newb to another; Should the ball thingy that the knuckles turn on be rusty and dry like in those pics? Do you need to add some moly grease to the knuckles via the square plug?
Another newby--similar problem
I have the heavy steering and mine pulls a bit to the right and the steering drifts at times--though no clicking yet. My axle looks similar to what you have pictured. I'm wondering if I should be seeing grease on the joint or not (is that normal?) or am I in need of an axle rebuild?
i figured that the heavy steering I experience is from lack of lube in that area, but I haven't gotten around to check it out. I drive my daily commuter till I find time to investigate this.
:confused:
is that rust?
I just tried to clean off the rust off the "ball", a lot of the stuff just came off when i spread with brake cleaner. Most came off with a bit of rubbing.
The question I have now is how do i keep a layer of lube (moly grease?) on the ball so it doesnt rust? I tried to apply a thin layer on there and it just get pushed away by the knuckle when I turn the wheel.
Ok so now I understand that the ball gets lubed by the grease in the knuckle.
1 new question. After I repack the axle how often do I need to check the grease levels in the knuckle?
As I understand the way it works, you don't and can't check the level of grease in the knuckle. It is repacked and resealed and should all stay in there as long as the seals are good. The reason you are seeing grease on the ball is your seals have partially failed and the grease that should remain inside is leaking out--hence the necessity for a repack. Someone correct me if I'm wrong.
Cleaning from outside really doesn't do much good. I did the same thing at the beginning too until I started to hang out on this board. I believe you can remove the wheel and take off the cap from the top to check/refill the grease. But if you go through that much trouble might as well rebuild it... There are many threads here covering a great detail of repacking the knuckle. Search for "Rebuild front axle" (you may want to use advance search and to limit in 80-tech only). Of course you may want to start with the FAQ. Elmariachi even has a DVD for it. Good luck!
