Yet another LS swap question.
Bakersfield CA.
I see alot of people retaining the stock fulltime T-case using the expensive Marks adapter. Has anyone looked into using the NP241 when swapping LSx/4l65e? My 40 has the 241 with SYE and drive flanges machined to bolt the stock Toyota drivelines to. No driveline to trans pan issues with it clocked flat.
Not an answer to your question, but have you considered the 60 series split case with the less expensive AA adapter? Keeps the drive line offset.
I believe it's a center output so you would need a centered rear axle and a modified gas tank.
Mr Cimarron you are correct it is centered rear output. Thats how it is in my 103" WB 40 with the rear axle flipped to allow for better alignment. I dont seem to have any driveline vibes and seeing how the 80 would have a longer rear driveline I don't see it being that big of a deal provided a CV driveline was used.
NCFJ, that is definately possible. I'm looking at all options at this point.
I would see if it would clear the gas tank even at that offset angle. I'm sure a broom sick or something like that could tell you real quick if it would work.
Yeah I'll put it up on the rack tomorrow and do some figuring. I have the T-case out of the 40 so it will be handy for comparison.
I run the expensive Marks adaptor and it works great. Also converted my t/case to part time and put the Marks gears in - they are quiter than stock which is a nice surprise. Not worth skimping if you have the coin- as part of the all-up conversion cost, Marks stuff wasn't that too big a part of the eqauation. I was bugging them nearly DAILY for the revised LS A/C idler pulley so I could finsih mine off as they are only 25 mins from where I work here in Aus.
That's just it. I don't have that kind of coin. The NP241 is not doable at all with the stock fuel tank. Time to fab a new rear tank.
