Yet another heater core question... Sorry
Decatur GA
How the F! do you get the rubber hose off the heater core from the inside of the engine compartment!!! I finally have the dash out and the heater core is now visible inside the dash area. I think the only thing still holding it in is the rubber fittings going through the firewall. I cannot find any more bolts but it would not surprise me a bit if I missed some of the 150 plus little f'ers. This job really does suck! And not to mention I have probably removed about 2 or more hours worth of crap that probably did not even need to come off. Thank god I finally just went ahead and took the hood off.
That is what I just did. Good ole slice and yank. I kind of like the idea anyway. I will be able to eliminate the old tee that was capped from the rear heater. Turned out it was a good idea. There was so much crap in the valve and hoses that I am just replacing all of it. Too bad I did not have the energy to go ahead and replace the rear heatercore and tubing. I really don't need it, but it would be cool to say it is working. Fan still works.
Has anyone ever successfully removed the heater core assembly without removing the AC condenser? I feel like it is sooo close.
