Yet another CDL/7-Pin Mod Question...
Athens, GA
So I have tried to search the forums or infer an answer, but haven't had much luck.
So I installed the CDL switch, and did the 7 Pin Mod a few weeks later. Messing around in my gravel driveway I've been a little concerned/confused...
So CDL + 7-Pin should yield the ability to turn CD off in low range, and turn it on in high range. That seems to be working.
But when I'm in Low Range, triple locked, the Axle Diff inidicators light up solid. Then when I switch to CD unlocked, in either high or low, the front and rear diff indicators blink. The wheels all appear locked when I've driven pre-CDL mods, but I haven't honestly tried it in mud or super loose sand, just a gravelly lot.
So my question is: Should the Front and Rear still stay locked upon unlocking the center, or would they unlock as well, only to re-lock automatically? I know I can check the acutators on the diffs, but wasn't sure if the blinking upon unlocking the center was normal.
The CDL has to be locked for the axle lockers to lock, so if the CDL is unlocked, the axle locker will also unlock.
I believe they will unlock when you turn off the CDL and then re-lock when it gets turned back on. But remember that "turning off" can take a while to physically occur (for both the center and the axles).
Ok. So to reiterate:
Center Diff locked in either high or lo range: Front and Rear Lockers will engage
Center Diff unlocked in either range: Front & Rear Lockers will not engage.
Is there any rationale for this? I guess as a regular (Locking Hubs, Part-time 4wd) 4x4, the center diff is locked when in 4wd by definition, then the axles can be locked. I assume this is essentially what is happening with the CDL?
I would have assumed you could still lock both axles, or at least the rear, with CDL unlocked.
Thanks for the clarification!
Short story, yes to your last post.
Reasons it's good:
-You can lock the diffs in hi range if on level/straight/"1 tire in ditch" scenario (granted engagement isn't instant).
-You can shift into lo range & not have to have the CDL if say, you are towing a boat up a boat launch ramp with out loosing the ABS - just dropping down a set of gears if you think you could use it for steep but not "treacherous" terrain.
It just gives you more flexibility & the fact is that if you find a need to lock a diff, then you probably could use the transfer case locked too
(That last is my reasoning it works that way).
Thought maybe it had something to do with the viscous coupler, but the trucks without VC's are built the same way. Don't really know why Toyota set it up that way. Sure does work though...
I have been wondering about this myself so when I saw this I figured I would ask being that I am still a NEWBIE
I do not have the Factory Locker
I just installed the CDL Switch but did not do the do the 7pin mod
it was my understanding that when I put it in low it just locks the rear and the same with the CDL Switch when I hit the switch it just locks the rear in High am I right or wrong.
Without the factory lockers, nothing is being locked in the rear. It's only the CDL central differential locker on the transfer case being locked and unlocked.
Now you can lock or unlock it in Low and High. Before the only option was locked Low.
What pkt said.
http://www.lcool.org/technical/diffs/diffs.html
ok thanks guys I understand it better now. I did look at many with the factory lockers but I went for the low mileage (59K) and condition and figured if I start doing heave off roading I can do after market lockers in the future but right now I am super happy with the whole set up.
The only thing the pin 7 mod does is allow you to lock the axle diffs in high range.
Nope, re-read above. CDL switch allows you to lock up in high range, pin 7 mod allows you to unlock CDL in low range.
Yep what lanb said. If you need further clarification go to slee.com
Quick clarification; what state is the vehicle in when engaging CD in Hi? ie can you do this while moving? Thanks-
Oregon. If it's not in Oregon, it won't lock.....
Don't know...... just being a smart a$$.....
CDL will lock while moving, F&R lockers might eventually, if you go around turns and stuff so the gears line up. F&R lock much quicker if there's slippage so the gears can mesh up, and they're un-needed at higher speeds.
The one guy in kansas that can read AND write.....go play with your slippers Dorothy:flipoff2:thanks for the feedback. I am still getting my feet wet in this LC disease.
Gentleman: I have done a lot of searching on here and can't find any thread dealing with proper lights when engaging and disengaging the CDL switch. After installing the CDL switch and the 7 PIN mod, everything works as it should but in High with CDL switch activated no lights come as in LOW. Additionally in LOW with the CDL switch out, both lights stay on. I know this is an old thread, but figured I would re-visit because it seems that some on this thread are very knowledgeable of the mod. Thanks in advance for any info.
When you say both lights, you mean CDL and ABS? Or what? You also say everything works as it should, but go on to describe how things aren't working as they should. Could you provide some additional info on your issues?
