Yes another flasher question
Oregon
So I need some help please. I've read a lot of the turn signal posts on the forums and I think I've narrowed it down. In the picture of the flasher I have confirmed that I have power going in and flashing power coming out. I bypassed the turn signal switch and went from the flasher directly to the in dash light , and it blinks. I tried to chase down the wires in between the flasher and turn signals but they go into the harness .
I'm not sure where all of the grounds are but I did clean the light socket and ground from the battery to the block and installed a new ground from block to the firewall. ( should it be to the frame? ) . Do you think it could be my switch? Is that a Toyota or Chevrolet switch in the picture? What year do you think the switch is? Thank you for your input.
This thing needs a new harness but I'm not ready to tackle that animal yet.
The column and turn indicator lever are not FJ40. It looks Chevy to me.
Your trouble shooting is pointing toward the switch in the column. Pull the column plastics and steering wheel and get in there where you can verify whether powerreaches the switch.
Roger that. Thank you for the reply. As you already stated and I was able to confirm that it is a Chevy column. I will disassemble and try to find the right parts.
I wouldn’t assume that it’s a parts problem yet. More likely still a wiring problem, but you need to know if you have continuity from the flasher to the switch, and then from the switch to the harness that runs out to all the lights. Depending upon where and how the PO spliced in the Chevy column you could possible rule in/out the switch by testing via the connecters that come out of the column. This can be hard to get access to sometime, so going right at the switch might be quicker. Depends upon what you find behind the dash
There is two three way splices at the steering column where the PO spliced three wires. I have no power at this location. I'm having a hard time chasing down where each wire is going to and coming from as it looks like a hand grenade has gone off under the dash. I'm going get into the switch tomorrow to try to understand better where these are going. I'd like to get back to you if you don't mind ? Thank you for your reply.
What year is your rig? Do you have the wiring diagram for it yet? I think it’s Coolerman who has a download page with many manuals and diagrams. If yours is a 75-79 I can email you a few things that will help. Message me your email address.
It’s a 71’ with a 75’ motor. A chevy steering column. A four speed and I’m not sure what transfer case.
The real question is did the turn signal flasher EVER work after the Chevy column install?
How about the Hazard lights? Do they flash?
Couple of years ago I wired an FJ40 harness to support a Chevy column. It was not an easy task to get both Hazards and turns working. Not knowing what has been done to your particular truck I'm afraid I will not be of much help. Here is a diagram of how I did it.
I had to use two flashers to make this work correctly.
Turn signals did work, then as they where actually flashing just kinda faded and stopped. I thought the bulb just burned out, then I thought maybe a ground. The hazards have not worked. Thank you for the diagram.
Next question is: Is the Hazard switch installed and PLUGGED IN? I'm pretty sure the Hazard switch has to be plugged in and working for the turn signals to work on the 1971 FJ40. Next is to check all the following:
Go to each light and open the housing:
Remove the bulb.
Verify it is the RIGHT bulb.
Test the bulb.
Clean out the bulb sockets.
Verify the light housing is well grounded.
Re-insert the bulb verifying it is installed correctly.
Repeat for all 4 bulbs.
That will eliminate the bulbs and grounds.
You already know the turn flasher works.
Remove the bulb.
Test the bulb.
Will do , thank you.
Remove the bulb.
Test the bulb.
Now I have no power to even the flasher. I’ve put this on the back burner as I’m about to give it a gasoline and match car wash. I’ve got a transfer case issue to deal with that is priority now.
I forgot to mention one very important thing on your 1971 FJ40. The Hazard switch has it's own fuse in a clear fuse holder that is taped to the main cowl harness about 6" to the RIGHT of the fuse panel. See pic
That is a 10 amp fuse.
The flasher is also fused with a 15 amp fuse in the fuse panel. Check that fuse first if you have no power to the flasher.
Dam I just had the heater out . It has a 75 drive train and different fuse box than a 71’ . I’ve looked at your site and your schedule and thought about asking you for a harness but don’t feel ready to tackle that animal. Also I need my shop finished so I can take my time. . Thank you for the info
Well it appears that the wiring is still OEM colors so that is good. They did a pretty good job of swapping in an aftermarket ATC fuse block.
The top 6 fuses will be always hot and the bottom 6 will be key switched hot. The secondary Hazard fuse is the bottom left. The one with the Green/Orange and White/Red wire on it. Check that one and the one taped to the harness. If they are both good, I would start looking at the Hazard Switch itself. It may need a good internal cleaning.
