Yellow box speedometer correction
I have purchased a yellow box and the plug and play adapter. Does anyone have experience or write up on how you mounted it on your 80? I could only find one write up. I am assuming that there are quite a few of you that may have one of these installed. Did you feed it inside of the cab and if so where did you go through? Any help would be appreciated. I have the v5 yellow box. It appears that it may be waterproof from the looks of it.
i spliced in behind the glove box. the adapter for the tranny came with but i figured it was going to be more of a pain in the arse to make a new hole or existing bigger. it was just a pain getting the 2 big connectors apart to splice. i used scotch locks to splice. you can then leave the yellow box in the glove box if you need to get to it, but once adjusted you shouldnt need to get to it again
Scotch locks suck big time. I refuse to use them. They don't belong in a vehicle (well, at least not one you care about electrical reliability), would be a good match with a landy though :)
A significantly better splicing system is to use positaps (Posi-Tap- No Crimp Tap) will cost you more, but they WORK and continue to work long term.
cheers,
george.
I use a yellow box. Not sure what version but 4 years old. I cut a slot in the transfer case shifter boot originally. After 3 years the boot ripped put. I eventually spliced into the main harness behind the glove box.
I removed the shifter console and unbolted the shift plate from the floor. Then I fished the connector between the transfer case boot and shifter. Bolted everything back down and ran the little controller to the driver side just by the hand brake. Reinstalled the shifter console and left the yellow box out so I could adjust it. Never bothered to poke it away under the console...didn't bother me at all.
