x
Title basically says it all. Are all the FJ55 rear heaters the same? How do they compare to an FJ40 rear heater?
Just mulling some things over:rolleyes::lol:
Howdy! I may have one if your interested. It was in very good condition the last time I saw it. Let me know and I can dig it out. John
early pig heaters and later ones are different as are the floorboards and mounting position; motors are the same but the difference in in the housing..........IIRC.....there are 4 mounting holes on earlier ones and later ones had 2 + they did not have a recess in the floorboards for mounting HTH
Lou
Rhino; IIRC.........there was a difference between the very early pigs.....prior to 72?; 2 bolts recessed....then the "middle" pigs with a recess and 4 holes and the :confused:78?......79s with 2 holes and no recess which placed the heater motor and core roughly about an inch higher; HTH
Lou
have seen 3 different original styles on piggies:steer:and same with the floor boards; seems they all had the same motor and "radiator".................about the same top but the differences were in the mounting base........question is when the cut offs for different styles occured:hhmm:HTH
Lou
